Wanted: Ignition housing for 68/69 bay
https://forums.aussieveedubbers.com/threads/75683/wanted-ignition-housing-for-6869-bay
simoninoz ·
Hi there,
I'm after an ignition housing - the alloy bit which the lock tumber goes in - which fits my type of cowling, described as the 'lip' type, as you can see on the pic. This is generally accepted as a 68 type, but I have one on my post-September 69 van. Just to confirm, I have the cowling already, it's what i'm pointing at below. It's the alloy housing i'm after.
The underside of the cowling accepts a different type of ignition housing - I've taken pics of my one (minus ignition of course...) and one from 1970 which differs.
Also, if you think you've got it and but still unsure the bolt holes for the ignition are wider than later ones and measure up at 62mm centre to centre.
I just need the igntion housing - the alloy part not the black cowling, I have a lock barrel, but if you've got the complete thing off a steering column i'd be happy to take that if it's a nusiance seperating it.
Cheers ,
Simon
now thats gunna B hard
I know Vintage have wrecked a few low lights lately so give eum a call
Klaus ·
good luck in finding one , there's 3 different types and the wiring on the back of the switch is different aswell , look at your head light switch and see if you have a black wire with yellow tracer ( "X" location ) going to it if it does you need an ignition with the same "x" on it otherwise headlights wont work , Just went thru all this on a mates bus ended up using a 1970 type 3 head light switch without the "x " on it and 3 x "30" positions to power it up . If you still have your switch from the ignition and h/light switch then ignore the ramblings just wanted to share the fun i had.
In the 68 low light sc i have i ended up putting a push button in place of the ign switch .
kombisaint ·
Hi , I got 1 here in Toowoomba , Qld , cheers Alec
alecbrown1@bigpond.com
0412126784
simoninoz ·
vw54 wrote:now thats gunna B hard
Cheers Dave, think I've shaken that tree already but I'll see again, see you at the show soon
simoninoz ·
Klaus wrote:good luck in finding one , there's 3 different types and the wiring on the back of the switch is different aswell , look at your head light switch and see if you have a black wire with yellow tracer ( "X" location ) going to it if it does you need an ignition with the same "x" on it otherwise headlights wont work , Just went thru all this on a mates bus ended up using a 1970 type 3 head light switch without the "x " on it and 3 x "30" positions to power it up . If you still have your switch from the ignition and h/light switch then ignore the ramblings just wanted to share the fun i had.
Thanks for the info Klaus, much appreciated, glad you got yours sorted one way or other
simoninoz ·
kombisaint wrote:Hi , I got 1 here in Toowoomba , Qld , cheers Alec
0412126784
If you have the alloy ignition housing Alec you da man, thanks for putting the pic up, i do have the cowling already that it fits into, i'll talk to you tomorrow, past polite calling hours now.
Thanks for prompt replies everyone
S
simoninoz ·
Still looking, thanks anyone
Old Dubber ·
from a '69 unmolested with original key
Grahame
simoninoz ·
Old Dubber wrote:from a '69 unmolested with original key
Grahame
PM sent Grahame
Simon
0435 062 358
