I have started my second suabru 2.5 ltr monster motor build
As I am after 200kw at the rears, the following will be able to provide this with rome to move to 220 kw at the rears. This is the run down on what I have collected to date to build the motor to power a vw.
The short block is from a subaru outback 2.5 ltr with a stock bore. Pistions and rods are from a crash test JDM 257 motor, bearings are ACL race series , heads are V3 sti with 750 cc injectors, I have had some work done to the heads porting and angle treatment. The manifold is from the outback with custom fuel rails,Turbo is a TD06 20 G with custom dump pipe & muffler.
Trans will be the custom built select-o-matic I have been working on for some time with a lsd center from a subaru diff fitted with custom out put shaft & drive axel flanges. I have used one of my subaru adapter plates & fly wheels to mate the motor to the trans. Drive shafts are billet jobs with 911 cvs & chrome molly cages.
Front brakes are Rx7 on billet hubs & stubs are sleved with CNC adapters , rears are ford
Now to get hold of Humptys notch 馃檪 or some thing ?
suitable
working on a ECU for the above now.
GTMac 路
Snds nice Neill, still thinking and you dont help posting stuff like this! 馃檪
What does the 257 stand for?
Andrew
trickysimon 路
My guess is hp although 257 hp only equals 192kw 馃
seagull 路
257 is late model semi closed block ,with forge pistions and better con rods for turbo aplications. I am closing the deck of the case with my N/A motor.
newoldmanx 路
seagull nice combo ive decided to go the subie rout in a buggy after running one in my dc for years i have stumbled across this from nz at what i believe to be the right price any info/feedback would be appreciated as i am far from knowing what im looking at at this stage
This is a complete Subaru 2.5 long block with NON AVCS heads with an FLI (Fine Line Imports) custom reverse intake manifold kit. EVERYTHING HAS 5500 MILES ON THEM! This complete Long Block comes with a Cobb Tuning Stage 1 block (forged piston, STI stock forged rods), Cometic .60 head gaskets, U.S. 2.0 liter WRX NON AVCS heads that have been ported and polished, 5 angle valve job, JUN 264 degree camshafts, JUN Titanium retainers and JUN valve springs. This engine has an overall compression ratio of 8.2:1 The intake manifold has been powder coated red, the APS 65mm cold air intake and intercooler piping has been powder coated flat black. The intercooler piping has been wrapped with Thermal Tech heat wrap and black netting for a clean look. There is also a Gruppe S header with Thermal Tech heat wrap and a Cobb Tuning stainless steel up pipe
cheers馃憤
GTMac 路
newoldmanx wrote:seagull nice combo ive decided to go the subie rout in a buggy after running one in my dc for years i have stumbled across this from nz at what i believe to be the right price any info/feedback would be appreciated as i am far from knowing what im looking at at this stage
cheers馃憤
And the right price is?
seagull 路
Seagull , this parts / como are the same as my other 257
I will be in Nz in a few weeks time . If its close to were I am , I would not mind having a look at it for you
newoldmanx 路
hey cheers seagull not knowing what im loking at or diong with subie donks I bit the bullet today and have placed an order through John Rykowski of outfront motorsports for a new 450hp "turn key" plug n play
the guy that just bought one of my other manx's "4bkila" is off to NZ tomorrow to look over the engine for his transplant
seagull 路
Ok , sounds sweet
JVLRacing 路
cheers馃憤
x2?
newoldmanx 路
bought it for for $4000nzd
GTMac 路
newoldmanx wrote:bought it for for $4000nzd
Thats pretty good considering his brand new 500hp motors are about $13knz. You will probably also need $4k spent on the gearbox to tame the beast.
