Good Spare parts?
https://forums.aussieveedubbers.com/threads/75709/good-spare-parts
desh ·
Hello
I wonder, what are good spare parts to have on hand for the discerning 6 volt Beetle owner?
What spare parts are good to keep in case something decides to give up the ghost?
I have x2 spare fan belts, the x2 sump plate seals, 6 volt tail light bulbs.
Are there anything engine wise that are hard to find or acquire as original items that should be snapped up and kept as spares? generator?
Obviously a spare engine would be nice, but any accessory parts of the motor that are good to have on hand?
rose ·
I have a large bag of goodies that I take away with me full of spares when I go on long trips in my bug.
For starters a throttle and clutch cable.
alien8 ·
Yeah, a spare engine would be the ideal situation.
Prob a starter motor would be a smart spare to have. A spare battery is also handy.
Spare accelerator cable, clutch cable and clutch pedal.
desh ·
A very good, given me some things to order, ill create this list, if others have anything to add Ill update it, thanks
accelerator cable
clutch cable
clutch pedal
starter motor
battery
spark plugs
points
condensor
fan belt
regulator
fuses
distributor cap
rotor
tappet cover gaskets
engine oil
spray degreaser
generator pully,
fuel line
fuel filter,
fuel pump,
carby
cable joiner using a wire block
a complete distributor pre set,
cable cutter
2 screwdrivers
a set of ring opender spanners
tin of mixed nuts and bolts
can of WD 40
a spark plug socket
electric regulator
, NRMA/RACQ membership
mobile phone.
plugs, points, condensor, clutch accelerator cables, fan belt, regulator, fuses, dissy cap rotor button, tappet cover gaskets, spray degreaser, engine oil, generator pully, coil,
fuel line, filter, fuel pump, carby,
greedy53 ·
fan belt, cable joiner using a wire block, if you hve one a complete dizy pre set , a length of old accelerator cable 3 feet and a good cable cutter , 2 screwdrivers aa set of ring opender spanners , a tin of mixed nuts and bolts , a can of WD 40 , a spark plug socket , and a elec regulator ,
taxi card 😀
rose ·
don't worry about spares just join NRMA 😂
for when it goes into tow truck mode
rose ·
don't worry about the spare battery as it will just go flat sitting around
Just buy a little Jump Starter you can get them for $60 from Repco or Supercheap.
colonel mustard ·
NRMA/RACQ and a mobile phone.
desh ·
rose wrote:don't worry about the spare battery as it will just go flat sitting around
Can you get 6 volt jump starters? I haven't looked.
But I have a 12 volt one and have used it many times for myself and when I've seen someone on the side of the road with a flat battery.
rose ·
Yes you can.
thugbug ·
A can of WD40 & a roll of Duct tape - If it don`t move use the Wd. If it does & shouldn`t use the tape! The nett result being a car held together with tape but doesn`t squeak! Now can some one cut me out of the car as i need to go for a p. cheers
mitchellgolds ·
The jump starter I have has a switch to switch from 12v to 6v. But it's almost older than electricity so dont go asking for where I got it or what brand it is.
I got from my father, if you were wondering. 😂
rose wrote:Yes you can.
whatnow ·
a manual to suit a your year model and a copy of the idiots manual.
ian.mezz ·
sOME PETrol and a bOX of matches 😂😂
rose ·
Ian Ian Ian I am not letting you anywhere near my bug.
Actually I was going to say a giggler hose and a spare 5lts of fuel if you have a bug with no fuel gauge like mine just for on long trips.
ian.mezz wrote:sOME PETrol and a bOX of matches 😂😂
desh wrote:Can you get 6 volt jump starters? I haven't looked.
Do You mean the jump starters with a battery in them??
I've only seen 12 volt models of those...
Jumper leads on the other hand can be used on ANY voltage - the thicker the better - and with good clamps on the ends that are screwed on -
A 6 volt beetle with an engine in good tune will always start with a push... use 2nd gear...
greedy53 wrote:fan belt, cable joiner using a wire block, if you hve one a complete dizzy pre set , a length of old accelerator cable 3 feet and a good cable cutter , 2 screwdrivers and set of ring open ender spanners , a tin of mixed nuts and bolts , a can of WD 40 , a spark plug socket , and an electric regulator ,
well I agree on the FAN BELT - CABLE JOINER for when the throttle cable snaps off next to the carby...
a cable joiner or a new clutch cable - manual cars.
VW spark plug socket - that lets you replace the fan belt too. - Can of WD 40 - Screwdrivers - spanners OE etc & sockets - New set of POINTS - New Spark Plug [1]
I also carry -
1 long Spark Plug LEAD - New DISTRIBUTOR CAP -
new ROTOR - new ACCELERATOR CABLE - spare SUMP PLATE NUTS - sump plate GASKET AND WASHER KIT -
new TAPPET COVER GASKETS - FEELER GAUGES - BATTERY JUMPER CABLES - 1 litre OF CASTROL GTX2 - new HEADLAMP GLOBE H4 -
a new CONDENSER in case My electronic ignition ever stops - DIGITAL multimeter - wires and screws -
Strobe TIMING LAMP - High capacity tyre pump -
The NMRA won't have a VW belt as they aren't common.
or points or plugs etc.... best to carry Your own..
alien8 ·
I kind of meant if one of the cells dies in the battery you would have a spare and jumper leads for a flat battery.
donn ·
Ha Ha, checking out the list of spares recomended here it's not hard to figure out we are driving old technology, and mostly worn out at that, aint it fun though.🤪
desh ·
donn wrote:Ha Ha, checking out the list of spares recomended here it's not hard to figure out we are driving old technology, and mostly worn out at that, aint it fun though.🤪
You do make a good point, preventative maintenance would include most of these items I imagine.
I'd imagine with the spark plugs if they are changed they should be fine for a few years, depending on amount of use.
rose ·
or points or plugs etc.... best to carry Your own.. [/quote]
If the NRMA can't get it going it goes on a tow truck no worries. NRMA do not keep a full stock of any belts on them and parts for any car.😂😂
thugbug ·
A good old hand pump. In case you have a FLAT battery! When acid level rises to top then the battery is fully 'inflated' !!🙄
newghia ·
You are all forgetting the bloody trailer to carry all this stuff !!!!
Just get it serviced properly, join a good roadside assist group (RACV etc)
& take the basics, Inc the mobile to ring someone at home & get them to bring you what you need !
grumble ·
That is an incredible list of parts,was this to carry with you or just as spares at home? After 10 or 11 years stored in the garage,we fitted new brakes,points & leads,changed oil,added fuel , a battery & a set of tyres,started up well,,registered and on the road to the Hunter Valley for Barls wedding.i did forget the NRMA road service,but it wasn't needed anyway as the little girl cruised at 100-110 very comfortably.. Note - Be very careful jumping a 6 volt battery with a 12v jump pack,I have seen them blow the top out of the battery.
rose ·
Note - Be very careful jumping a 6 volt battery with a 12v jump pack,I have seen them blow the top out of the battery. [/quote]
Just disconect the negative wire from the battery then start it with the jump pack, then take off the jump pack then replace the negative wire.
grumble ·
Smarter than the average bear Rose,i just didn't want to lead anyone into flashing 12 volts across a 6 volt battery,as i stated i have seen a few explode and it's not pretty.cheers les
desh ·
grumble wrote:That is an incredible list of parts,was this to carry with you or just as spares at home?
I was more thinking at home yes, but no harm in talking about things to include in the car.
Although I tend to break more than I fix on cars, I do carry a small toolbox with screwdrivers, adjustable wrenches, rope, tape, pliers, wire, cutters, Stanley knife, etc..
Anything I can do with these is about the limit of my mechanical skills anyway..
68AutoBug wrote:well I agree on the NEW FAN BELT - CABLE JOINER for when the throttle cable snaps off next to the carby...
[a cable joiner or a new clutch cable - manual cars.]
I also carry -
1 long complete Spark Plug LEAD - New DISTRIBUTOR CAP - new ROTOR - new ACCELERATOR CABLE - spare SUMP PLATE NUTS - sump plate GASKET AND WASHER KIT -
Strobe TIMING LAMP - High capacity tyre pump 12v-
DUCT Tape - can be very important...
piece of vacuum hose -
Now all these things do NOT weigh more than a spare tyre/wheel - and I don't carry a trolley jack as they are too heavy... only a VW jack....
Now - for extra spares at Home -
Headlamps H4 Bosch & Hella x 6
Tail lamp lenses - New x 2
Blinker lenses - New x 4
Accelerator cables x 2
Disc Brake pads - New Set
Accelerator pedal rubber x 2 New
Headlamp rings - used by 6
tail lamps /blinker units used x 4
wiper blades new x 2
Hub Caps - used x 8 -
NEW rechromed NOS x 4
Headlamp H4 Bulbs x 4
Torsion bar seals x 4 new
Brake caliper kits x 2 new
Dizzy caps rotors points NEW
oil cooler seal kits x 4
push rod seals x 32
fan belts x 3 NEW alternator belts
spare used oil coolers -x 3
spare fan housing and generator with fan
spare used switches and knobs
New oil temp sender x 2
sump plate gasket kits x 6
tappet cover gaskets x 24
spare door handles x 4
New set of door cards -
spare fuel gauges - and VDO gauges -
gearlevers etc x 3 used -[auto]
headlamp/blinker VW relays - used
spare control valves - dual pump
clutch servos - torque converter etc
CV boots - circlips etc..
Engine C/S seal - torque converter seals
wheel seals and bearings - NEW
voltage regulators used x 3
Windscreen rubbers x 2
Window rubbers x 1 set
New rubbers for Engine bay
speedo cable New & used
etc etc....
as you can see- I Must have spares.... lol
