rear axle nut size
https://forums.aussieveedubbers.com/threads/75744/rear-axle-nut-size
grogy ·
hi, whats the size of the rear axle nut ,36mm ? is it the same on both irs and swing. thanks for your imput
13bwagon ·
hi mate yup same for both or i think some kombis had 40mm nuts wish i had a set of 40's
where are you from other people might be able to help that are local
and they are hard to get off buy a nice 36mm socket about 20 bux 3/4 or inch and a nice bar to suit the put a pipe on the end
also you should have left the cv's on as you will want the car in gear !!!!!!!!!!!!
grogy ·
thanks , i went to bunnings n supercheap, only go to 32mm, now im lookin on ebay. i usually do most things back the front, but at least i only do it that way once.
grumble ·
Try Toolies they have good quality tools at a reasonable price
rob53 ·
Most trade tool shops have them. Gasweld, Glenfords and etc.
volumex ·
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7036
This tool gets rear axle nuts & pulley bolts off easily - worth its weight in gold.
tassupervee ·
volumex wrote:http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7036
Yer can vouch for that.
Ive had one for ages. A really handy tool.
Especially handdy if you want to remove the nuts with the box out of the car.
L8tr
E
cb john ·
Hi Evan, hope to see you at the Nationals...
