Hi all ,
As seen below we have plenty of GOOD second hand parts for most models .
So if your looking for that odd part more than likely we'll have one .
cram ·
hey andrew -
This is wacky - I need to drop some gear off for Dan tomorrow (I hope he's arranged it with you!) and I was just looking at your website and saw you were only open mon-fri ...so was going to put a post up here to see if that was the case...and you beat me to it by 6 mins.....thats great service!
btw - do you align bore T1 cases?
OZ Towdster ·
Sorry we don't do line boring , but i can arrange for it to be done for you and yes i know about Dans gear
555bug ·
great news for those of us who are slaves Monday to Friday🙂
11CAB ·
Well thank those who are slaves Mon-Sat......
555bug ·
thanx 😉
OZ Towdster ·
Amongst some of our hidden treasures here at custom are the following .
This Trip Speedo is in great condition and as rare as these are we would be looking for offers over $350.
Sorry i cannot read the date on the rear
OZ Towdster ·
We also have these 50/50 taillight lenses , a little faded and would suit a great rat 60/61 beetle
OZ Towdster ·
Plenty of other tresures hidden upstairs too .
Single port Weber manifolds
1200 & 1300 tinware by the drum full
Plenty of good straight rust free beetle doors from 62 - 76
3 off lowlight bay front bumpers ( 1off is even a deluxe with horizontil overiders )
A pair of primered and straight late type 3 guards ( Have had rust repaires to bottom and are fully welded patches )
Plenty of aftermarket seats
A set of type 3 Z bar armrests
15 odd late beetle deck lids some no vents some 2 vent some 4 vent , plenty of each to chose from .
Approx 3 complete baja kits ( Not all kits are a full matching set )
colonel mustard ·
oh how I wish I had money. 🙁
Anthiron ·
andrew, do you have a manifold that would suit a weber dcn14/holley bug spray????
im looking for one for my bugspray that has pre heat tubes or at least a brace to the case bolt for my single port engine. 3 peice style is ok, ive got single port end peices.
Nicko
OZ Towdster ·
Nick you have 3 to choose from .
I will post some more photo's soon
Anthiron ·
nice one!! cheers andrew, ill be in brissy on wednesday thursday. so i can drop in if its what im after.
Nicko
OZ Towdster ·
A bugspray has a similar bolt pattern to a dcn weber yes ??? and what size heads have you got 1300 or 1500 as the inlet holes are different dia
Anthiron ·
its the same bolt pattern as a dcn 14 weber (the later one with 4 bolts not the older 3 bolt weber)
heads, thats a good question, is there an easy way to check? did VW not make 1600cc sp heads?
OZ Towdster ·
Anthiron wrote:heads, thats a good question, is there an easy way to check? did VW not make 1600cc sp heads?
Yes they did but i think they are the same inlet size as 1500 heads .
As for which ones you have , there is only one way sorry to say and that is to pull of your existing manifold and measure the holes although now i think about , mabey its only the inner part of the stepped inlet hole that is a different dia from 13 to 1500 heads which in that case my manifolds will definetly fit which ever head you have .
With your bugspray base being the same as a dcn i have definetly got at least 3 different manifold that will suit what you want and 1 is even a nice cromed one although it doe's need a good polish and they all have good heat riser tubes as i don't believe any of them have ever been fitted to an engine
Andrew
Anthiron ·
sounds great andrew, how much for the shiny one😏??
ive got a few DCNF manifolds kicking around and also had a bugspray on a single port manifold as well but chucked it
the bugspay does have a smaller bolt pattern than DCNF but most DCNF manifolds have the holes slotted so u can squeeze a bugspray on
nick if ur worried about stabilising the carb/manifold without a preheat i made up a bracket for one of mine that bolted to the case cos the preheat had rotted off and it flopped around
let me know if u need pics and lengths etc
Anthiron ·
joel yeah ive seen the brackets, if you have dimensions that would be fantastic, (sorry, bit of a thread hijack)
colonel mustard ·
Go to CVD everybody, the staff are awesome. 🙂 (espeically pete)
Anthiron ·
ive started another thread for this topic in tech talk, sorry andrew
colonel mustard ·
Andrew, do you have any single DCNF manifolds??
bajachris88 ·
any second hand sets of 4 stud wide 15inch rims for the baja Andrew?
1916baja ·
I don't think so man, I have been calling everywhere to find some including custom vee dub. I am looking into getting some made.
ang3lsholocaust ·
you've got a PM andrew👍
71-BEETLE-SEDAN ·
Hey, dunno if this is old thread or whatever but what aftermarket seats do you have, i am looking or a pair.
