Are the Kadrons same as Solex?
https://forums.aussieveedubbers.com/threads/758/are-the-kadrons-same-as-solex
karmannghia60 ·
I apologise if I am asking a silly question but are the two the same?
kombi_kid ·
yes they are dont worry i didnt know either till i asked that same question to a bloke at a swap meet! just a bigger version i think
rhys
70AutoStik ·
Actually, original Solex carbs haven't been made in (I think) about 17 years. Kadron carbs are the Brazilian made (under licence) version - the good news is they made larger ones. The largest original (VW) Solex carbs could only make about 80HP tops (by theoretical flow.)
Grey 57 ·
What type of Solex carb is sold as a kadron dual carb set. I have a set of T3 carbs and single port manifolds that I want to put on the oval. Are these the same. What do I need to do to the linkage setup to make it all work.
How much extra power will it create and it is it all worth it? :o
vwrallycar ·
the carbies in question here are single throat 40mm twin carbs. they are not standard vw carbs. as for the type 3 carbs i think they are 32 or 34mm single throat. i think if set up properly they should give you some gain over the standard single carb. but if you can afford it i can certainly recommend the twin kadrons
Grey 57 ·
Will the Kadron linkage set up work on the T3 carbies?
70AutoStik ·
The type 3 carbs are 32mm at the butterfly - not sure why they're called 32/24. They give a little more HP due to improved flow and leaner mixture, also give a snappier response- if you've got 'em, throw 'em on in lieu of the stock single.
Grey 57 ·
Thanks for the info. Biggest prob for me is the linkage. All I have is the carbs & the short manifolds. Can't seem to work out in my mind how a standard T3 linkage would work. Iv'e seen the T3 set up, but in a T1 the generator stand looks like it would be in the way?
Cheers🙂
70AutoStik ·
The Type 1 linkage works the same way, it's simply organised to be at a different height. You could probably use the kadron lingage, but it pretty expensive, or I saw a setup where a guy had put a "Y" into the cable and simply ran a direct pull - but I can't rememer how he balanced them.
Grey 57 ·
I was thinking about the cable idea myself. Would work but it must be easier to adapt T3 linkage. Think I'll buy one and start playing around with it.
