Aussieveedubbers · Bugs
"Bolt Ons"
https://forums.aussieveedubbers.com/threads/75860/bolt-ons
milestones54 ·
Hi guys, just lookign for some quick advice.
looking for abit more power and trying to eliminate the signature bug engine note from my standard 1972 1600 bug
What are some quick, reasonably easy mods to achieve this somewhat?
Im looking at upgrading ignition system, new exhaust and hopefully new carbs
Speaking of which, because this is my first vw can someone let me know if im running single or dual port?
A pic is below, hope that helps
First of all you have a dual port
See the rubber bits that connect to the cast aluminium end castings on your manifold?
You will see they splay out to 2 ports as opposed to a single port that has......... well ....... one port
As for bolt ons - read here
http://www.aircooled.net/gnrlsite/resource/articles/mods.htm
A VW doesnt need much to make it go good
Handling will beat power most times
make sure your motor is well tuned and concentrate on handling
A set of lowered struts with heavier springs
a set of type 3 rear torsion bars and new gromments
KYB gas shocks on the back and say some Boge inserts on the front
decent rubber on widened rims
new bushing and coupling and a short shift kit for the gear stick
Adjust steering box or replace if you have to
its a dual port engine
easiest and best bolt on are
electronic ignition system
quite pack exhaust system
check all yr tinware is there as well
Sides ·
Also related to the tinware all being there, best to connect the hoses from the fan shroud to the heater boxes down underneath... or at minimum plug them up to keep the airflow under control.
yep as per above
It looks liea n OLD engine of unknown qty
you dont want to be giving it too much other wise you may be re building it very soon
milestones54 ·
thabnks for the quick replies
First off, since the photo i have connected the hoses
Im not looking for a heap of power, just something to keep up with normal traffic abit more and hopefully a nice exhaust note at least
What exactly does "tinware" include?. between where the hoses connect i have another circular hole which i can see the floor underneath
milestones54 ·
Also what does the short shift kit comprise?
My gear changes at the moment dont take a whole lot of effort and there was a gene berg shifter in place when i bought, is there a chance i might already have one? is there a simple way to check?
well all the engine bay tin is in place by the looks
quiet pack mufflers dont sound anything like a stock exhaust and give alot better flow
nice deep crisp note without being loud
my thunderbird quiet pack is actully quieter than a stock pea shooter muffler
as dave said electronic ignition, gets rid of those dinosaur points
twin carbs offer a nice improvement even on a stock engine
short shifts just reduce the gear change throw by lifting the gear stick up which changes the pivot point
havent clapped eyes on a berg shifter for years but pretty sure they are quickshift by nature.... as in its part of the assembly
eraser ·
grab yourself an EMPI exhaust system changes to a nice deep rumble 😉
colonel mustard ·
thunderbird >>>>>>>>>> any empi exhaust.
jsheppard64 ·
u could get ratio rockers which increase the lifts of the valves
now standard lifts is about .250" at the cam at the valve is .275" (1.1:1standard rockers)
with the 1.4 rockers lift @ valve is increased to .350". don't bother with the 1.25 ratio
however with most ratio rockers you'd require shorter pushrods and stronger unless u can get them from some dude as a kit.
also while carbon silicon insulated spark leads are friendly to your radio and such copper leads deliver slightly hotter spark compared to carbon leads (carbon leads usually have around 5k Ohm resistance depend on the length) you already have 5k Ohm in the rotor anyway.
alternative from electronic ignition u could probably get high energy ignition or CDI from jaycar
i saw a CDI kit for about $20 this CDI will work on vw engine but you'd need to do a bit of rewiring
well not really an alternative since you can have cdi triggered from electronic ignition
ratio rockers are wasted unless you really improve on the breathing
theres so many varibles with each engine like deckheight etc so shortened pushrods have to be tailoured for each indiviual engine so its not really possible to just sell kits
Berg shifters are available in 40% and 60% reduction in throw/travel. Do you want to sell it?😂
milestones54 ·
Hahaha. i know how special that chrome thing in my hand is :p
Now im even less willing to part with it now that i know its short shift
I have heard the same with the rocker. 1.25s relly arent worth it and 1.4 need different sized rods
At the moment im thinking electronic ignition in conjunction with new 009, a new exhaust (iv seen the "gt" i think it was, on cvd for about $300) and hopefully a twin carb set up, but i really dont know where the prices start for those, as iv mentioned in another thread i can get my hands on some 45mm dellortos but they are way to big.
I dont want a big increase, but id like a nice sound and abit more pull
those GT mufflers are your base product and dont really offer any worthwhile gains
for $300 it better be the stainless version
best all rounder for stock to mild engine has always been the quiet pack, been that way for decades
nice flow and sound good without being loud
ground clearance is the only problem with them if on a lowered car
just steer clear of any with the Empi label on
build quality is atrocious, fit is even worse and they start falling apart pretty quick, but thats to be expected with the price they sell for
I would wait with the oo9 until the carbs come along, as they can be a pita with stock carb, but definately a good 4-1 extractor system, ie. not a GT or Monza, the hide-away my choice is it is less visual/ugly, it puts the muff up under the guard, altho needs to be removed for routine valve adjust. Go see Westi (westside mufflers), he'll sot you out, s/s and all.👍
ctefeh ·
Hmmm...looks like a converted semi-auto motor. Does the carby say H30/31 on the float bowl (side facing left as you look at your piccie)?
If it's a 34 Pict 3....I'd call it a converted donk because of the carb and vacuum spigot on the centre section of the manifold.
Ctefeh
milestones54 ·
any pics of this quiet system? iv heard alot of them
And price?
Exhaust is first, im not in a hurry for ignition or carbs
trickysimon ·
Could just be a semi-auto manifold ctefeh. My manifold has the vacuum port as well. (Also has same ignition leads and chrome airfilter. Had to look twice to make sure it wasn't a picture of my engine 😂)
milestones54 ·
Dont suppose your still on red p's like me? :P
trickysimon ·
Not since August. Got my Ls, red Ps and green Ps all on my birthday. (Someone was eager) 😂
milestones54 ·
Damn u must be younger then.
I got my reds at 19 and got them suspended for 6 months
Terrible, learnt my lesson though, i drive like an old woman now
trickysimon ·
Well we will see how long I last when i get this 1916 in 🙄
milestones54 ·
Want to trade for a nice little Gene Berg? :p
trickysimon ·
Sure. You send me the Gene Berg and when I recieve it I'll send the engine off (Don't hold your breath) 😂
milestones54 ·
are these the quiet systems?
and any approximate pricing?
milestones54 ·
and yes i im aware it says quiet on both , im just making sure :P
trickysimon ·
Yep, thats them.
milestones54 ·
I just realised those one say to 71, mines 72 im guessing they would stock a similar item?
yeah thats them
badly worded add, will fit all 1300 and bigger bugs but only type1 kombis which stopped end of 71 in the US which is were george got those specs from
i run the single quietpack but the thunderbird version not empi
main thing is they hang down pretty low
sorry its not a good pic but u can see theres not much in the way of ground clearance
milestones54 ·
Clearance shouldnt be too much of a problem, im running a little lower than stock height, but i want to keepo the stock look.
I really wanted something that would exit through the stock holes but id rather the performance
Is the one advertised the empi version?
Sometimes the CVD ads are very confusing, but its the only place with the info :p
these are the tuckaways matt mentioned
theyre essentually a quietpack but the muffler sits up under the gaurd instead of hanging down below
staino version is on special atm 🤓
milestones54 ·
Should get my mitts on them asap then!
$400 bucks for that in s/s has to be the one to buy. Heaps better than the std qp location.
milestones54 ·
I just ordered it, such an impulse buy :P
Is it still possible to use the heater systems with the high mount?
Yep, heater boxes are retained with the one in the pic.
milestones54 ·
Oh kewl! Lucky, its getting damn cold, having a scarf doesnt help that much in a convertible :p
ctefeh ·
TrickySimon/Milestones,
The inlet manifold centre section can be found on some bus motors too. If the carby says 34 Pict...that's the reason I say semi-auto because of the vacumm take-offs + manifold.
You won't find that particular 34 Pict carb on a bus motor unless it's a H30/31 instead of a 34 Pict.
Regards
Ctefeh
its a 34pict3, 31s have a much smaller base
its a bitsa motor and not the original, evident by the lack of an engine number
one of mine is all the same but only cos i put a manifold off a bay on it which has the semi auto port for the brake booster and the carb had the retard ports blocked off
jsheppard64 ·
this may be a bit late but if you can weld things together.. or get exhaust custom made here's some ideas
this is actually what "quiet" system is with 2 resonators and a lukey muffler all 1 3/4" all you can hear is the fan and induction noise of twin solexes. see that the ground clearance is bad it's like 4" off the ground. but it's nice for everyday driving cost me about 150 for the 2 res and a muff
and the other is the show set custom made with steelwool filled sound like canon on a commodore and loud cost me $10 for a roll of fine steel wool
colonel mustard ·
Cant steel wool catch on fire???
trickysimon ·
Only if you put a current through it.
milestones54 ·
Nice job!
Im guessing it fits ok in the wheel arches
I dont so much want it quiet, just a different exhaust note
colonel mustard ·
there you go. i thought it was heat as well. clearly not.
wow blast from the past, a 2 bolt kadron header,
i once had a dinosaur exhaust system too 😂
Pauld ·
iv got kadron 2 bolt on my bug too
byronmcmanus59 ·
i've seen steel wool ignite just from sun through laser light.. trust me that shit goes up..
modulus ·
hth
