Empi Strut Inserts
https://forums.aussieveedubbers.com/threads/75903/empi-strut-inserts
konewone ·
Trying to lower 75 front end and have an Empi 9627 Strut and an Empi 9630 Stut Insert ready to go on but the cap only screws up about three threads and then bottoms out. According to the catalogues I have the right parts but it just doesn't seem right. Anyone seen this before or have tips?
welcome to the wonderful world of empi
where Everything Manufactured Passes Inspection
every kit ive see is like it, just make sure theyre uber tight and they'll be fine
i put a set on mates Sbug and he came back a month later and said front end is clunking when he braked
a found the left one only finger tight.....
konewone ·
...every kit ive see is like it, just make sure theyre uber tight.
Cheers for the reply.
I have loctited the caps in and done them up FT.
The car looks great, handles well and all seems OK. I will keep a close eye on it.
Another forum another guy had the same issue and did the same thing and has never had a problem and when he checked them later, they were still tight.
On another point Empi parts are a bit of a trial, the holes in the bottom of the strut were too small for the bolts and the strut hit the bracket that it bolts into. I would have thought that it would have all fitted together without me having to modify it all.
Anyway, lost a Sunday but the car looks wicked.
yes, everyone's had to open out the mounting holes thats par for the course, but did you have to grind the bottom corner off slightly to get the bottom hole to line up
most 2 bolt empi struts need that done to fit
someone on SBO or samba did it the other day and the picture they took showed the problem beautifullly
konewone ·
someone on SBO or samba did it the other day and the picture they took showed the problem beautifullly [/quote]
I saw that pic on Samba and that is exactly what I had to do too. How do we get this feed back to Empi?
its all coming out of taiwanese sweatshops,
im sure it would only fall on deaf ears
konewone ·
...and to think that my local Vee Dub shop recommended it.
empi is always gonna do a roaring trade because people dont wanna spend the money on better quality parts and suppliers look more attractive if they can sell a cheaper product
EMPI some good cheap rpoducts you have to pick the eyes out of them to get the good stuff
And some utter crap especially the tawianese webber copies that leak petrol through the fuel bowl castings
