Hi All
I'm planning a turbo 2332 motor for my 1500 and am a bit overwhelmed by the choices available when it comes to heads, cams and headers. Hopefully some of you out there can givie me a bit of giuidance 馃槉
The car - Street registered, some hillclimb and drag use (not that there's a lot of options around Canberra for now). Performance-wise, I'm looking for something that will run mid to low 12's on the 1/4 mile. It's all about fun, I'm not chasing trophies or anything liked that (they move to fast for me anyway 馃槀).
The engine - 2332, forged pistons/cranks etc. microtec controlled efi through a PWR air/water intercooler and ida downdraft manifolds, turbo will most likely be around T03 size. Looking at about 8:1 static compression and hope to use high octane pump fuel.
Question 1 Heads and Cam - I 'd like to keep engine revs sane (around 6 - 6.5k) so I'm not rattling the rockers off it. That being the case can I be a little conservative with the heads and cam and go for mid-range designs and use the turbo to make up the majority of the grunt? Does anyone have any suggestions? (Keep in mind I have a mortgage 馃槀).
Question 2 Headers - There seem to be two popular options when it comes to off the shelf headers, 1 and 3/8's or 5/8's. Would the smaller diameter help keep lag down or will I need the bigger flow numbers?
Cheers Guys
Brett 馃檪
justbrett 路
