Beetle Single Port Twin Carbi Setup
https://forums.aussieveedubbers.com/threads/75917/beetle-single-port-twin-carbi-setup
whatnow ·
36hp, 1200, 1300 or 15/1600?
OZ Towdster ·
I have some single port DCN Weber manifolds .
OZ Towdster ·
Sorry i only have a manifold at this stage , but a DCN Weber shouldn't be to hard to find , just make sure it's a good one .
My manifolds are basicully new although that was 20 odd years ago they have never been fitted to anything .
With a single centre mounted DCN you won't need any linkages and i would highly recomend this option over twin carbs .
Andrew
wiseoldub ·
how much for one of your manifolds? i am after one!
cheers josh
0414 726194
Anthiron ·
i have a 40 dcn 14 weber i want to sell, god knows where it is but its around also have a manifold and brand new empi single port end peices (these are over 100 bucks) all you would need is either to weld on some heat risers or make up a bracket to one of the case studs to stop the carby rocking back and forth.
karmannghia60 ·
Isn't the 40DCN a single carby setup? He's after dual
Anthiron ·
yeah its single, but he said he might look at a single if he cant get duals, its in the first post.
Camo ·
Rastas4, I sent you a PM days ago. I have a brand new, still in box, Empi twin carb setup for single port, linkages, manifolds etc. Everything needed and hasn't even been removed from the box yet. My plans have changed as I just bought a motor with carbs.
Reply to my PM if you are still interested.
Kev
