autolinia alloy cases new in box std 1600 replacement $900/also have set of 4 300ccford motorsport injectors o ring type 20min running perfect condition oring type $300 need any more details call rudi in sydney f9 SOLD 0418442953
LIFE IN THE LOW LANE ·
webers have manifolds, linkages etc etc?? Obviously type 1 manifolds I presume if they are with the carbs.
bigrudi ·
webbers sold / fuel reg comes with f9 setup
Captain Cockatoo ·
mmm used F9 900
a new E6 is not much more than that
bigrudi ·
e6 computer may only be a little dearer but is the cheapest part. then you have to set up your harness buy all senders,map,air temp,oil temp and connectors tps switches injectors,fuel regulator, then you have to tune it as well add it up then add another couple of hundred and you will be geting close to the price .i must be bored even responding to that last post,hope ive enlightened you this is the real world. Rudi
give ya $650 for the case 😉
colonel mustard ·
Can anyone one tell me anything about the case?? IS it better/stronger than standard?
hellbugged ·
so what exactly comes with the F9.......no ignition contol with them?
harness/loom
sensors?
injectors?
imagine the programming is complete with all maps, start ups, temp correction etc??
tempting
bigrudi ·
computer comes with harness connectors allsensors air temp map tps oil temp fuel pump relay,4x380cc injectors all maps set up, used this computer on my 72x94 engine 1998cc in L bug sport sedan to win2x nsw state u/ 2ltre supersprint championships made 120hp atw on pulp cold start map set perfect wasrunning 009 dizy with modifted advance graph made similar powwer with e8 halteck that fitted on same engine.to complete this set up you will need .VLfuel pump throttlebodys 45ml injection perfection to suit oring injectors and fuel rails also surge pot. BARGIN Rudi
