Early type 3 body wanted
https://forums.aussieveedubbers.com/threads/75995/early-type-3-body-wanted
satori ·
Wanting to get into the early type 3's. I have a late square with good running gear and would like to find a early square or fasty body. if you have something give us a PM. Will the early body fit onto the late pan?
thanks
1500S ·
There's a good early Notch in Melbourne on evilbay with quite a bit of work done on it by the look of it. Has late rear suspension already fitted. Saw some mention of it here on cars for sale.
DH
PS. The one under your post in that section. http://forums.aussieveedubbers.com/viewtopic.php?tid=75738
GTMac ·
How much work do you want to do? I have a 68 Fasty with IRS suspension. Rough paint, but quite solid considering. Needs rust repairs done around water box area but this is usual and easy fix as its straight plate and hidden behind guard once done.
Its currently running an EA82 Suby motor and good SSP L Bug box. Do a search under my name and should find the add from a while ago. Its located near Concord. Asking for $1500 and it comes with some good spares.
Andrew
