The Subaru engine had done about 90,000km so I replaced the timing belt and whatever else was recommended at the time. I have been VERY happy with the engine.
Now, 55,000km later it seems the crankshaft oil seal is leaking and needs replacement. Do people have suggestions of other items that ought to be replaced at the same time (i.e. while I have that end of the engine in pieces)?
Thanks folks,
Dave 馃槑
(Just returned from a 3,500km jaunt from Brisbane to Tocumwal, Echuca, Deniliquin, Bourke, Cobar, Lightning Ridge, Dirranbandi, Goondiwindi and home. I really enjoyed driving the van - a camper - especially with cruise control!)馃檪馃檪
ratbug 路
Not much else in that side of the engine, you could pull the inspection plate off and reseal it with silicon, just in case that starts leaking (held on with about 10 phillips head screws).
Did you replace the camshaft seals when you got it, these can also start leaking along with the crank seal, but they are in the front.
Joel 路
Dave i just got d茅j脿 vu reading that as i already got the email from SV 馃槀
is it the pulley end seal or the flywheel end seal?
there both fairly similar to replace but if its the pulley end while its off its worth checking the oil pump which is behind for leaks as well
Transparu 路
Thanks Joel and ratbug.
Sorry, it's the timing belt end of the engine.
OK I'll look at the oil pump seal too.
Dave
ratbug 路
Ahh I thought you meant the flywheel side.
Ok well, the oil pump seal is the pulley seal. If your changing that you'd be taking the timing belt off etc etc, so i'd at the same time do the cam shaft seals. You'd be kicking yourself if you went to all the trouble changing the oil pump seal, and then a few 1000ks later have to take it all apart again to do the cam seals.
