Intermittent wipers
https://forums.aussieveedubbers.com/threads/76017/intermittent-wipers
GTMac ·
Guys whats the best fix for this? Is there some contraption that I can adapt. Dont want anything big and bulky and of course hidden. Hoping to adapt to a spare hole in dash.
Getting sick of turning wipers on and off and am anal about keeping them on.
greedy53 ·
any wiper switch will do the job, it's only a matter of wiring it up grab a sweitch and wander off to ya local sparkey
Andrew
I put them in my 65 Orange Smoothie remind me next time i see u to show
Get the head section of a series 1 golf so you have the twin wipers n blinkers set up it might take a little stuff round to fit it ot the type 3 it will look stock and no extra holes i think the steering tube is the same as the late type 3
the wiper has the intermittent position which is to pull down plus 2 speeds
you also need the relay also when you pull back to activate the washer the wipers swing 3 times to clean the screen
talk to steve carter when hes back
he setup his yellow bug same as dave but also added varible dwell setup as well
my daily has this feature and it really makes a big difference over fixed intermittent
GTMac ·
Thanks Dave, thanks Joel, will check it out next time I see Steve and likewise Dave down at VVW.
Special Air Service ·
vw54 wrote:Andrew
Dave,
Will this fit around a 1500 beetle steering column & shaft or do you need to install a later beetle shaft that has the same splines etc as does the MkI Golf?
Brendan
