Jake Raby burnout video
https://forums.aussieveedubbers.com/threads/7604/jake-raby-burnout-video
Below is a link to a Jake Raby burnout video, they are using a wheel chock to hold the car in place, interesting.
http://www.volksport.net/images/video/burnout.wmv
1302Steve
Dasdubber ·
Yep I saw that today - cooked the "ashpalt" until it broke up in bits! It helps to be an engine builder after you hammer your engine that hard for that long!
zac_smits ·
i can only see the 1st 15secs of the video...doesn't even get to start his burnout
Would have gone for twice as long if he had used a Type 1 motor with a Progressive Weber 😀
Any idea who owned the green bug - didnt do any where near as good.
With Kadrons Barry 3 times as long.
What was all the water on the ground for ???
HotRodMatt ·
What's that? Birchall praising Kadrons?
Must need a new prescription for my glasses.... LOL
BiX ·
Hey with a burnout , do vw's have the same problems with cooling as water cooled cars? As or cooling is only related to engine speend, eg, more rpm, more air, while water cooled cars have to have air flowing through the front. does this mean the vw can do burnouts without overheating?
Che Castro ·
i dont think burnouts make that much load on the engine, plus when the engine is at that speed the fan is spinning pretty damn fast.
A properly setup cooling system is sufficient to cool a stock engine going up a hill.
Baja Wes ·
Che Castro wrote:i dont think burnouts make that much load on the engine
You obviously haven't done many burnouts before.
An aircooled car will get hot doing a burnout just the same as a water cooled one. Try using full throttle and high RPM in a high HP motor and you will find it heats up, car moving or not.
PS - I've seen Jeff Unwin do better in his old hellbug with no wheel chocks. Oh, and I hate *wmv files.
555bug ·
i had a quick read about this video on STF and Jake mentions its bouncing of the limiter at 7~8k...my ass!! give me some chocks and a puddle and I'll pop the rear tyres on my wifes stock 71. Guess you have to generate a lot of hype to sell those 6k + ($us) motors
555bug
I think u hit the NAIL on the head ... why my 36 Judson powered car would do the same....
I think they like water over there
Baja Wes ·
I put the front bumper of my old supasports buggy (1600 twin port, stock carb, cracked heads) up against a tree and funnily enough I could do a burnout too.
If he actually used oil instead of water then he woulda got more smoke, so maybe he did that.
