are the steering box & idler arm actually mounted to anything that wont move? doesnt look like it from those pics
Kappage ·
the idler arm is the steering box WAS but when i turned left it went fine
and when i turned right it didnt work which was kinda weird so i took the steering box one off and im rethinking on how to do both if neccesary
STIDUB ·
by the looks of it id say the lengths of angle you welded in to mount the steering box & idler arms stops the arms from them to the bar that joins them together moving, cant be sure because of angles of pics but id suggest remount the steering box, disconnect the column from the box at the uni joint then push/pull at the wheels while looking for things interfering with anything that moves, might be worthwhile looking where the body has clearances for moving parts & try to make the mounts more like that if possible.
