Aussieveedubbers 路 Tech Talk
Replacing Oil Cooler Seals
https://forums.aussieveedubbers.com/threads/76150/replacing-oil-cooler-seals
sander288 路
Found the culprit for my leaking engine... I just wanted to know what is the right sought of seal for a 1300 SP and the correct way of installing them
Cheers馃槉
68AutoBug 路
sander288 wrote:Found the culprit for my leaking engine... I just wanted to know what is the right sought of seal for a 1300 SP and the correct way of installing them
Cheers馃槉
If Your engine still has the original oil cooler inside the fan shroud... not out the back of the fan shroud [doghouse]
the seals are 111 117 151 these were used up until the doghouse oil coolers were introduced...
the better looking and working oil seals are 021 117 151A
with the 10mm holes... and the seals are stepped on both sides...
using a late model oil cooler or adaptor You use
111 117 151C which are stepped on both sides...
8mm on one side - 10mm on the other...
I am using a late model adaptor and hoses going to the oil cooler located under the car...
8mm on the engine and 10mm on the oil cooler adaptor
111 117 151A or [kit 111 198 029 with steel washers]
I believe my oil seals may be leaking too...
certainly have a leak there...
sander288 路
Looking on CIP1 at the original seals, they arn't the ones that came off, the appear to be the A series ones with the stepped rib, however this may be the cause of the leak due to incorrect seals, i'm going to call Vintage Vee Dub and order some original ones, becasue I do have the original cooler and motor.
vwvic 路
If you put plenty of permatex on the seals when you put them in they won't leak
Ever again
greedy53 路
i to have a leak there and turned out to be the hose just needed a bit of a tighten so i changed them and used turbo clips that use a wider band
RISKYBUG 路
hey mate
if your in trouble i have a few new oil seal like i said in your other thread
and have you started work at the pub yet?
