Indicators dont work at all. Can anyone tell me how to test the relay switch?
what year and model ??? check the wires first
kombivw ·
71 bug But just had a brain wave. Will use relay switch from Kombi
Euro_67 ·
Check the fuse box. Sometimes the fuses & holder oxidise. Give them a bit of a clean / rough up with some sandpaper or use some contact cleaner. My wipers and indicators often randomly stop working because of this. A quick fix is to rotate the fuse in the holder to get a better connection.
colonel mustard ·
Bulbs, fuse's, contact points, relay... ? Fun.
greedy53 ·
do the lights come on but don't flash i'd go with a fuse than work up till ya find it
david try the flasher out of the kombi
everything after 70 used 3 prong relays
9 times out of 10 its the relay that goes but also the hazard switches have a habit of falling apart
with the ignition on if you pull the hazard switch does the speedo idiot light come on and not flash?
kombivw ·
Clened the two prong relay terminals and indicators worked. Hazard lights do not at all and dont show on speedo idiot light either?
