Turbo54 wrote:If your talking about adam's car for the classic adelaide - I think there wedge ports not comp elims. I know hes got comp elims on this turbo car. I have street elims 44x37.5 on my 2165 turbo car yet to be run but thought they were plenty big enough for the size of the motor. Adam rand 44x37.5 streets on his turbo car daily and never had heating issues so it must be a myth. Would it not be better to spend the $$$ on something else like efi or something after all you only searching for 11hp?
T54
Not Adam.
EFI will cost more than a set of heads,
and be lucky(very lucky) to be 11hp better than a correctly jetted set of carbs that have the same venturi/throttle size.
The 044 casting would need material welded back into the port
to make it the same as a street eliminator.
The bolt pattern at the head is the same but the port shape is totally different.
I have not seen yours, but next time you get to do a comparison you will see the 044 likes a manifild that cmes in a little more vertical.
and the SE has a port floor that is much more horizontal.
The SE cooling rumour came from the Bergs.
There is no doubt that they have less fin area,
but to claim that they would fall in half if you drove them more than a 1/4 mile was pure hype.
The ones I know of travelled thousands of miles
of street and highway miles with 10:1 or more comp.
They probably had extra oil coolers,
and actually tuned their jetting and ignition timing to be correct
