VDO Tacho questions
https://forums.aussieveedubbers.com/threads/7629/vdo-tacho-questions
duncombemu ·
I've just bought a S/H VDO 3" tacho.
It's got no fitting instructions with it.
On the back is this:
5 little switches with each switch numbered from 1-5 with the word, "open" above the 5 numbers.
It also has 4 contacts below, with +, HI, LO and and an 'earth' symbol.
Can anyone help with these clues?
Regards,
Mark:thumb
Robo ·
For a 4 cylinder VW, the number two switch on the back should be down, all others, up.
+ to 12 volt positive terminal controlled by ignition switch
HI To negative terminal of ignition coil
LO not utilised
last terminal to negative (earth)
Hope this is what you need.
Rob.......
duncombemu ·
Thanks Robo, it's now working OK.
Mark:thumb
