i was sanding the floors with a wire wheel on the grinder and i mist have hit a weak spot on the brake line and its punctured.
what do i do?
this kinda sucks as i drive this car every day.
Nicko
hellbugged ·
know the feeling
get a new one!.........
you might be able to get your local brake place to make one up using the ends from your old one.....if your lucky the may be able to make some sort of "adapter" piece to get it fixed quick
otherwise try VVDS, i got one of them, very nice.........make sure the grommets in the firewalls are good or replace them, so you don't wear the new one through.
OZ Towdster ·
Nick , i have new long lines in stock and am thinking about comming north for a sail tomorrow , so could bring one with me if i come .
Andrew 0411556744
Anthiron ·
fixed.
massive thanks to andrew and eileen for opening the shed up on a sunday to help me out., i cant recomend custom vee dub enough!
new line went in pretty well. i was surprised, bleeding took a while but ive never bled from an empty or almost empty system before.
