metal plate under pedal assembly
https://forums.aussieveedubbers.com/threads/76312/metal-plate-under-pedal-assembly
cnfabo ·
can anyone tell me which way this goes.i wasnt taking any notice when i pulled the pedals out....
i put it back in with the 2 raised parts facing up and away from the front. im assuming the 2 raised parts are to stop the clutch and brake pedal falling to far back ???hhhmmmm
oh yeah,64 beetle....
OZ Towdster ·
Yep you got it right , now just adjust it so as the clutch and brake pedals are slightly leaning back and paralel with each other and all will be as it should be .
cnfabo ·
CHEERS ANDREW
Old Dubber ·
Chris,
Adjust the pedal stop so there is a clearence of 1mm between
the push rod and the bottom of the piston. This play can also
be measured as free travel at the brake pedal.
The free travel for a Type I is 5-7mm.
Important, the pedal travel must be large enough so that if one
brake circut fails, sufficient retardation can be attained with the
intact brake circut without the brake pedal touching the cross
panel. A template was provided by VW to check this. The
distance for a Type I is 205mm.
Grahame
baja burley ·
is this plate absolutely necessary? i didnt think it was....
