i purchased 3 point kafer bar off craig and still getting bad axle hop if i launch up to 4000rpm but anything over that i get lots of wheel spin.
on the rear i have adjustable spring plates, koni adj reds, camber compensator, and 205-50 kumho ecstas,medium compound.
any suggestions as i was told the kafer bar was all i would need to stop the tramping....
Sides ·
"if i launch up to 4000rpm".... does that mean it does it even at low rev's ??? (say 1500 or so)
If so it could be clutch shudder... feels kinda the same as axle tramp, except will do it without spinning the wheels...
what mounts are you using on the gearbox ?
Tramp is a combination of the forks flexing as well as the gearbox/engine moving on its mounts
The K Bar stops the forks from flexing, but it wont stop the gearbox/engine moving if you haven't upgraded the mounts.
grogy ·
have u got a bar under the rear of u motor?
cnfabo ·
no mounts and no tramp bar....
sides, say 3000-4000rpms it will tramp..
Sides ·
Right, OK - I'd be thinkin along the same lines as Craig then... mounts.
Assuming "no mounts" means the standard rubber mounts... maybe go up to a set of urethane mounts F & R and a strap kit ???
Solid mounts if you're really serious, but that'll be pretty noisy in a street car...
hellbugged ·
mid "BERG" mount on gearbox?........
yeah, engine mounts both 2 at rear and front must be good
torsion bar rubbers OK?
You supersrinting at the nats Dave???????
Sides ·
Nah Daimo - unfortunately not - got family stuff on that weekend that I just couldn't get out of...
hellbugged ·
🙅.....soft.......said else where, you are welcome to stop here as the half way rest/sleep stop and convoy it if you change plans.
yeah family, understand, i'm in trouble 😀
Sides ·
Just had a phone call with the fam... there's a now a possibility I can make it...
(btw sorry Chris for the hijacking 😊)
FROSTY ·
Hi Guys,
Had the same problem over the weekend couldn't stop it from hopping. After taking the tranny strap, tramp bar, shockies and sway bar from my other car it was either the clutch or the cable tube (bowden tube I think it's called) all it took was a couple of washers at the gearbox end making the bow in this tube about 35mm. Fixed it, no bounce at all.
westi ·
from my experience over the years,solid mounts,good shocks.no tramp ever.
ever ,ever,
i had never even seen a kafer bar until about a year ago.and as far as i can see unless it holds the engine and or box or both,how could it stop your engine and box from moving(tramping).it will stiffen up your arse end,just as good as some hemroid cream, but you will still need to hold your engine and box pretty firmly,strap or solid mounts.
any how that's my buck fifty's worth.
Berg midmount and urethane or solid torsion bar bushes should be fitted for control of hard launch, assuming clutch all good. I'm cheap....only 2c😉
cnfabo ·
my gearbox rubbers are stock and in good condition and i have just replaced the torsion bar bushes.
i have just received my heavy duty mounts that i go off mark on AVD,but wont be installing them anytime soon.
so what would be the verdict as thats why i purchased the k bar because i thout it stops axle hop, without all the other shit you have to put on aswell.????
beetleboyjeff ·
I agree with Frosty, check your Bowden tube has enough bow in it.
cnfabo ·
bowden tubes all good, i had my engine out the other day to replace pressure plate " calapsed dighram" and replace clutch fork,T/O bearing so i checked everything else.....
BiX ·
Also are they early or late engine mounts? the later ones were big and allowed allot more movement. The earlier slimmer ones don't allow as much. I did the swap and reduced the tramp allot.....
bajachris88 ·
Theres no one shaggin roughly in the back seat is there 😂
BiX is right about the tranny mounts
what year bug?
the later mounts both front and rear are really shitty design and so's the gearbox cradle
u cant do much bout the front mount but i swap all my late bugs to earlier rear mounts and tranny cradle
the early cradles are much stronger and better built and have better design mounts
from memory its 72 and earlier
cnfabo ·
the bugs a 64.
not sure if there late or early mounts already on there.
looks like ill have to put up with it till im ready to install the heavy duty ones.....
