Up for sale is another set of 2.5 inch dropped spindles for kombi, to suit all balljoint kombi beams. However, they can only use rotors and calipers from 1973-1979 kombi's - these calipers have a larger bolt and different disc offset to earlier rotors and calipers.
$700 firm, Pick up only from Mount Pritchard (liverpool area). Contact Geoff on 0416067932 or 9711 4383
benbus ·
Are these welded?
urban_myth ·
yes they are welded.many hours are spent toget the quality required.they are first preheated and then welded more than once to get ultimate strength where needed and then allowed to cool overnight.a little grinding is then required to get the finish as seen in the picture which appears like casting. to have these spindles fully cast fromscratch with all tooling done would cost about $1400 per spindle
