melbourne,3163
engine # T1007009
ph 0432880932
asking 4k its on ebay.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=200342041085
1973 Type 3 Fastback 1600
Project car that Ive enjoyed injecting (its dual carbs) some life into..now onto the next project.
It drives great and sure turns alot of heads. All in all a great little unique classic cruiser.
The good stuff -
Bare metal respray with etch primer , rust spots in front guards top/bottom treated and repaired.
Sprayed in original "Gemini Blue"
Lowered front, stock rear.
New polished alloy Empi 8's with new 195/50 bridgestone Turanza
New front Koni Special D adjustable shocks (reciept)
New front upper/lower balljoints (reciept)
New Bosch leads,rotor &plugs.(reciept)
Soundproofed engine bay/rear seat.
Exhaust repaired (reciept)
Relaced front seatbelts
Recent tune & service (reciept)compression test shows motor still tight.
Will include floor jack - original one not great
The not so good...
Carpet- none at present. Have original so can use as pattern, Door cards. Drivers non -existent, passengers average .
Seats. They are ok..I can live with them but you may want to recover or replace. 195/50 on front driver does scrape occasionally. need 175/55 or 165 to remedy or curl guard lip. Stereo. Was going to install brand new sony unit & sony 6x9's. will sell for additional $150 if wanted
Windscreen - could use new one. Ignition. works fine but barrel is on outside of column
crunchyyy ·
