Aussieveedubbers 路 Tech Talk
Ignition barrel removal
https://forums.aussieveedubbers.com/threads/76643/ignition-barrel-removal
dubsurfer 路
Gday all, my wifes 72 superbug ignition has stopped working.
The key will not go all the way round, it goes far enough to disengage steering lock but will not fire the starter. I have removed the push on wire cluster (at rear of barrel ??) and hot wired car and everything works fine.
I guess itis a mechanical failiure inside barrel, but i cant work out how the little sucker comes out.
Can they be repaired? Can I get a new one?
very occasionally I think it would be great to have a modern jap car that worked everytime,,,,,,,but thats just occasionally馃檪 Thanks for any info!!
Joel 路
funny last time i did this i took all the pics to a do a how to article to put up on superbeetles only as it gets asked all the time
I totally forgot about it......馃槉
guess heres a good reason to finish it off
Joel 路
some reading for you 馃槈
http://forums.aussieveedubbers.com/viewtopic.php?tid=76646
dubsurfer 路
Thanks Joel, you are a lifesaver
