Swing-Axle Wheel Noise
https://forums.aussieveedubbers.com/threads/76722/swing-axle-wheel-noise
rob53 ·
On my 1500 beetle, the left rear wheel makes a bit of rattling noise like the rim isn't tightened, or axle nut is loose.
I tightened the axle nut very tight with a huge breaker pole and it's definetly the right torque. If I push and pull the wheel it rattles (not much really), but the right wheel doesn't.
Any suggestions what I can look for?
silver ·
I'd check the wheel bearings
greedy53 ·
yep sounds like a bearing is kaput
rob53 ·
I'll have a check. That axle is always troublesome, I have replaced the bearings about 4 times, 5 boots, and replaced the axle as well. Admittingly, the last bearing changed was when the axle was replaced about 4 years ago. 🙄
silver ·
Check the Axle is Straight while it is out
a bent axle will chop out bearings regularly
zayus ·
Stop doing burn outs! 🙂
