swap rear disc kit
https://forums.aussieveedubbers.com/threads/76724/swap-rear-disc-kit
grogy ·
hi, i have a rear swing axle disc brake set up [4stud] and want to swap for a [4stud] irs rear disc brake set up. thanks greg
bushed ·
is any of the front gear any good to you?
cheap from me t3 72 discs & hubs 4stud pls email
bushed ·
also calipers and some pads
grogy ·
thanks for the offer, but i have the front already
grogy ·
bump
mackaymanx ·
Why not just use them with a spacer?
grogy ·
it appears the rear disc hub is wider [to the wheel bolt section] so it mean the wheel is about 15mm out further, any ideas?
