Aussieveedubbers · Country Buggies
Knobs and Ignition Switch
https://forums.aussieveedubbers.com/threads/76726/knobs-and-ignition-switch
bearwin ·
guys there are two knobs on the dash one is for lights and what is the other for? since the wiper motor has switch on it....
what ignition switch should I use? how do you install? pics would be greatly appreciated...
58camper ·
On the RHD models it is the left hand side switch that is used as the windscreen washer pump assembly. This pump assembly is as CB specific part number and I have never seen a new one. The right hand pull switch is for the lights. Orginally both of the switches were ivory (Part 111 941 541)
The ignition switch is Type 1 Part #111 905 811C described as Ignition/Starter lock with key. It is attached using a small screw mounted on the removable pod where the speedo and switches are mounted.
Where abouts are you located Bearwin.?????
countrybuggybill
ztnoo ·
Bill,
As I recall from the Samba ad last fall (US fall), the ad stated the car was in The Philippines. I do also remeber at that time bearwin was in San Diego, CA, USA.
His profile still reflects that, although it may not be up to date.
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=35842
I'm curious as to were the car is. Is it still in The Philippines, or has maybe it be sent to the USA???
Regards,
bearwin ·
the car is still in the philippines, as my homeland, it will stay there for a while....
