Subaru EJ22 ecus
https://forums.aussieveedubbers.com/threads/76746/subaru-ej22-ecus
seagull ·
seagull Neil
Perth wa
0407074141
I have the following Subaru EJ22 ecus. Thinking would make some one a good spare under there seat
$50.00 + $12.00 post
Gen 2 seriers 2 liberty
Numbers as follows
22611 AB640
A18-000 RV2
gaz58t2 ·
Hey Seagull
I have a pre May 94 EJ22 out of a liberty
Think its a 1990 engine
Were do you check No,s
would be intrested if you have the correct type ECU
Cheers Gaz
seagull ·
Pm sent
gaz58t2 ·
Hey Seagull
Did you get my PM
Cheers Gaz
seagull ·
no Mate I did not . I see you paid for the ECU but I dont have a delivery address to send it to you
try again
gaz58t2 ·
Will do
seagull ·
bump
boof2332 ·
Hey seagull,
You may be able to help...my mate has a ej20 in a type3 kombi that he just bought. The motor is apparently a 96/97 although they are saying it is out of a limited edition liberty 2.0l model. No one seems to be able to locate an ecu for him. The motor is quad cam. ecu is a gen 3/f3? I will get him to post the ecu number when he gets home.
Hope all is well with you and the family
boof
seagull ·
Hey Matt , yes all well at this end my boy is 10 now ( how time flys ).
The Ej20 N/A motor from what I can find were quite rare , the 2ltr quad cam motor cam I have came out of rebadged Isuzu station wagon ( JDM import half cut )
over the years I have only every seen a hand full of these closed deck 2ltr quad cam motors.
Your had best make a call to Al at AM Auto is brissy, Al may well be able to help you with a stock ecu.
regards seagull
