Finally ready to run a couple of new hard lines for EFI (one day project).
The shop has pipe called Bundy Tube.
Is this suitable? Anyone used it?
Newt
Turbo54 ·
Yep, it is the right stuff to use. go the 10mm (8mm inside diameter)
FInd my post in the members rides to see how I ran mine if you are interested.
Buy a good quality bender otherwise you will kink it and it's ruined.
Turbo54
cb john ·
The Bundy Tube is generally used for the brake lines, but if OD & ID is correct, I don't see the reason why not to use it...
Newt ·
Thanks Guys
Newt
Newt ·
Turbo 54
Checked out your build. Did you secure the fixe line inside the tunel?
