Aussieveedubbers · Bugs
gearbox/ brake options
https://forums.aussieveedubbers.com/threads/76894/gearbox-brake-options
sgetty ·
hey all
I have upgrated on my 64 bug to disc front, want now to do upgreade the rears also looking at prob 1600 engine
so whats my options for brake and gearbox
want to be able to do 100 on the highway without reving too hard.
cheers deon
Hi sgetty
You could go early Type 3 rears if you want to stay wide 5, they are much bigger than stock bug brakes.
Your transmission has
1st 3.6
2nd 1.88
3rd 1.23
4th .79
and 4.43:1 diff
So at 5,000 rpm with a 600mm (used this size as an example) tyre
1st 35kph
2nd 68
3rd 104
4th 162
Early Type 3 transmission has
1st 3.8
2nd 2.06
3rd 1.32
4th .89
and 4.125 diff
1st 36kph
2nd 67
3rd 104
4th 154
Early Type 3 & 1500 bug transmissions can be fitted to your car, but they have long axles, these look a bit dorky on early models.
I'm too tired to work out other ratio options but you can plug your ratios into this page http://www.albinsgear.com.au/ratiocalc.html
sgetty ·
thanks steve
how do they look dorky?
sgetty ·
my bug has all the 63 specs so 1200
The stock wheels are pushed out right to the edge of the mudguard
