Aussieveedubbers 路 Type 3 and Karmann Ghias
replacement indicator arm for early type 3 ideas?
https://forums.aussieveedubbers.com/threads/76925/replacement-indicator-arm-for-early-type-3-ideas
type3lover 路
Greetings!
My indicators won't cancel and the assembly is shagged.
I need to find a replacement whether vw or something from another car. Mine is the early type steering column.
What are people using?
Cheers, T 馃憤
1500S 路
But which "early" type. The one with the steering lock/ignition switch across the top of the column or the simple one with ignition switch dangling below column ? The top ones are as rare as rocking horse .. well you know .... but the lower one can be addapted from a similar model Bug. You will have to fiddle a bit to put the headlight dipper switch into the arm.
DH
type3lover 路
Thanks Dallas
Mine is the same ignition switch as the lower pic.
Can the beetle arms you mention be purchased new still and are they any good?
I have the dipper switch integral to the stalk. How much "fiddling" are we talking about?
1500S 路
Have my phone number in PM. Give me a call in 10 minutes.
DH
grumble 路
Weren't these similar to the ghia?
type3lover 路
Thanks D great chatting with you!
Hey Grumble I have no idea...maybe someone else knows?
Still looking...
1500S 路
A Bug assembly will be ok but he may have to put up with an ivory one. Can't remember if Bugs had the black things..... toooooo long ago! Only a coat of paint though.
DH
Klaus 路
converted mine to dipper switch think it was only drilling and tapping a very small hole for switch to pivot on .
type3lover 路
Thanks Klaus that's pretty much what 1500S mentioned to me as well.
I have been told that mine is most likely serviceable so I'm going to have a go at it...starting with disassembly and a good clean!
Still, I do like the idea of a non VW one say like a BMW or similar (german if possible!)
Spent hours at the wreckers and couldn't find anything suitable.
hellbugged 路
not cheap, but have recently seen new ones (yes type 3 with dipper) going into a hot rod.........will find out where they came from.
type3lover 路
Thanks Daimo!
Interesting choice...was it a VW hot rod? 馃榿
If you do happen to find out that'd be cool.
U have a PM too
Cheers! T 馃憤
REDKG 路
ghia & type 3 are the same. early ghia used the switch to flash the headlights and type 3 used it for hi/lo beam. i used a beetle one , just swapped the switch over. there are repro ones about.
