healthy EJ20T compression test number????
https://forums.aussieveedubbers.com/threads/76945/healthy-ej20t-compression-test-number
hellbugged ·
anyone know the PSI figure off hand for a compression test on a subaru EJ20T??
healthy number?
bad number?
hellbugged ·
prime time bump
ratbug ·
I think I was getting about 10-10.5bar, so about 150-160psi?
hellbugged ·
👍 tar, i'm getting 165PSI on the two i checked, so sounds good to me............might be able to stop grinding my teeth and have a decent nights sleep instead
seagull ·
Damo , 165 psi would be what I would expecting . I have seen 190 psi on newer motors
hellbugged ·
thanx Neil
jzk25 ·
165 is very healthy. Must be a late 90's engine at that. The old clanger RS turbo engines only have about 135psi. As long as they are even and above 130ish it is fine. When EJ20T's lose compression they do it in a big way as ring lands break or pistons melt. The engines don't really wear out, they will do 500k kms without wearing the crosshatching off if they don't get cooked to death in the mean time(this is what normally happens).
hellbugged ·
cool, yeah engine 2002.......wouldn't have done 20 hours work yet.
