What Oil
https://forums.aussieveedubbers.com/threads/76987/what-oil
sander288 ·
Changing the oil on my 1300 tommorow, I've often used the Shell old engine stuff, but I was trying to remember what some other people have used with good results, I think it was a Castrol oil GTX?
anyway what are you blokes running and what works best?
sander288 ·
looked on the Castrol website, they actually recomend the magnatec oil, so I think i'll go get that
1916baja ·
I heard the magnetec is no good for vw's, can't remember why but??? I use penrite hpr 30. Used it once and never looked back! My car stopped leaking so much oil when i started using it.
RISKYBUG ·
yeah i wouldn't use magnetec in this area this time of year something thinner hpr 30 i would like to try
have a search
greedy53 ·
i use a pensoil straight 30 had no problems over the years
h ·
I use penrite hpr 30 or 50 if your motor is a little tired
I've used 30 for the last 15yrs in all my rides n have never had a problem
go the penrite
castrol meh
polak ·
heard that castrol turns ur motor black inside, more so then most. im currently using valvoline low vis 10-30 in my new motor and for me its the best iv used so far.... on the old 1300, i used a number of things but got the best results from valvoline xld plus. iv been told by many performance vw ppl that a monograde 30 gives the best of both worlds in an aircooled motor, but i cant seem to find one so personally never tried it.
polak wrote:heard that castrol turns ur motor black inside, more so then most. im currently using valvoline low vis 10-30 in my new motor and for me its the best iv used so far.... on the old 1300, i used a number of things but got the best results from valvoline xld plus. iv been told by many performance vw ppl that a monograde 30 gives the best of both worlds in an aircooled motor, but i cant seem to find one so personally never tried it.
I use GTX2 in My beetle... with no problems.. 20w/50
I wouldn't use a monograde oil in anything...
Ask anyone what color the engine oil is when its drained..
SHELL:
CALTEX:
MOBIL:
PENRITE:
VALVOLINE:
I believe all engine oils now have detergent in them...
something that wasn't in 30 grade oils back in the early 60s..
so all engine oils should clean out Your engine all the time.
same as deiesel engine oils... and they are black ASAP..
colonel mustard ·
thinner oil in the winter! but not much thinner.
I use penrite non burn....
darren-h ·
penrite classic 30 or hpr 30 👍
greedy53 ·
we must remember that vw oil is also for cooling as well the book i read ay 30 graed for the best performence
mickmick ·
When i got my bug serviced at Vintage they used Nulon 15w/40.
polak ·
SHELL:
CALTEX:
MOBIL:
PENRITE:
VALVOLINE:
i used gtx 2 for a while on the old motor aswel and never had a problem, reason i switched was that i was told by numerous ppl that it stains the internals of your motor. obviously all oils go black with use due to contaminants and heat. derr🤪
as for the monograde 30 idea, i change my oil every 1500 miles, my car is no longer a daily driver and usually only gets taken out for a nice run to the beach or a blast down the track, so all the benefits of a multigrade oil only hinder my engines performance. YES muligrade oil is better if you are doing high milage or you drive in all different conditions but if ur car is strictly a toy to play with on weekends you could use a mono grade. although this argument is redundant as i cant find a monograde 30 anyways.
here is a quote from a chemical engineering website, it explains it a little better than i can.
"Oils used to be sold mostly as single-grade products, and still are for some special uses, such as extreme weather conditions or for racing cars. But the viscosity range of single-grade oils is too limited for general use. That's where multigrade oils come in.
High-molecular-weight polymers (viscosity index improvers) such as poly(methyl methacrylate) and ethylene-propylene copolymer are added to a low-viscosity oil base stock to create multigrade oils that work through thick and thin. At cold temperatures, the rubberlike polymer molecules exist as balled-up coils and don't thicken the oil significantly
But at warmer temperatures, they expand to more linear random coils to prevent oil from thinning out too much"
mickmick wrote:When i got my bug serviced at Vintage they used Nulon 15w/40.
I have heard of people using NULON 15w/40 oil
but its still too thin for My liking...
15w/50 Yes.... but not 15w/40
I was going to use Castrol Magnatec 15w/40 in My beetle but castrol doesn't recommend it... GTX2..
actually 15w/40 may be better in the winter in a 1500 engine with small oil galeries...??
Oils ain't oils.....
I recommend against 50w oil , too thick for proper cooling, and I'm in Queensland. Penrite is also questionable as too how they measure thier viscosity as thier oils always seem way thicker than most other brands, and since it's the volume/flow of oil that is a major part of our cooling system (thicker oil will show high pressures and lower oil temps as its not got the volume to wash the heat from the pistons as much as a thinner oil). I recommend a thinner oil, unless the bottom end is nearly falling out of the engine when a 50 grade Penrite would be a good choice.
I use and recommend Brad Penn or Castrol magnatec depending on owners requirements.
polak ·
im using valvoline low-vis 10w-30 and im very happy with it..... not much thicker then running in oil.... great engine response. wouldnt recommend it for older engines though, would probably knock a bit.
66deluxe ·
Brad Penn 20w-50 or castrol Edge 20w-50, go for an API SG rating oil.
RED62E ·
I just bought 5lt of Nulon 20W - 50 High Kilometer Engine Oil. Seems to be doing ok so far.
depends on the health of the engine
20/50 is like tar
fine in old worn shitters that need it to keep some oil pressure up but fresh new engines are generally happiest on something like 10/30
i run mine on 10/30 pennzoil
like polak said im not real impressed with castrol
the engines ive pulled down that i ran out were very sludgy inside
when i decompressed my 1776 after nearly 4000kms on pennzoil it was still cleaan as freshly built inside
problem with thicker oils in fresh engines, well dual releife blocks anyway is the excess pressure is bled off thro the valves and bypasses the oil cooler which pumps the oil temps right up
RISKYBUG ·
sander288 wrote:Changing the oil on my 1300 tommorow, I've often used the Shell old engine stuff, but I was trying to remember what some other people have used with good results, I think it was a Castrol oil GTX?
and soon in our area we will be hitting 10 deg in day time and - 10 at night so a little thinner is better
type3lover ·
Whatever happened to that ACE 30 stuff that was around a couple of years ago?
I usually use GTX2 in my VW's and change it often, but my turbo motor will most likely get mobil one fully synthetic one it's broken in (gotta save up for that!! 🤪 ).
OT: Can't remember where I saw it, but I read somewhere not to use synthetic in a fresh engine either...run it in on mineral oil then swap to synthetic after x number of miles.
Might be to do with the bedding in of the rings?
sander288 ·
Changed the oil today, I bought some Penrite HPR 30, seems to be working well, no leaks at all, except for me being a idiot and not looking whilst filling it up and spilling some.😂
so far Penrite HPR 30👍
trickysimon ·
I'm using 20w 50 in my 1600 and its just fine. Granted that it isn't the best condition engine around.
Valvoline, you know what I mean.
polak ·
type3lover wrote:Whatever happened to that ACE 30 stuff that was around a couple of years ago?
ace 30 is still around, i saw the guy down at the portland drags earlier this year. not sure how to contact him, but i dare say u would find something if u googled it....
BRUTUS ·
ACE 40 (25W-50) and 30 (20W-40) are both available in Sydney from CLASSIC Vee-Dub (George), and VINTAGE Vee-Dub (Boris).
There may be others...? Or Ask your favorite VW store to stock it!
OR "QPL" (Quality Performance Lubes) will courier orders direct (Min. order is 3 x 5L, or 1 x 20L) anywhere in Australia. Phone Neil or Ian on 03 5367 8794 BH. They will take credit card over phone (or post a cheque, etc.).
QPL (the only Australian manufacturer) is at www.qplubes.com which doesn't seem to show up well in searches.
Application/technical enquiries re 'ACE' Air Cooled Engine oils can be sent in writing to aceoil@optusnet.com.au
Anthiron ·
i run GTX 2.
so Mattberry and Joel are you saying its a little thick and a bit shit? my engines about 8 years old and mostly stock.
its fine in engines with a bit of mileage
just not when theyre freshly built with nice close tolerances it leads to oil pressure being way to high
the engine combats this by bypassing the oil cooler so it heats up more and thins out which just leads to high oil temps
well thats on a dual releife case anyway
pretty sure the single releife dont bypass the cooler
Anthiron ·
my case is dual releif, and i dont have a pressure guage at the moment (well its sitting in the garage 🙂 ) dip stick is never too hot to touch after driving, usually only warm.
baja bugs usually have that strange condition of being overcooled 😂
Anthiron wrote:my case is dual releif, and i dont have a pressure guage at the moment (well its sitting in the garage 🙂 ) dip stick is never too hot to touch after driving, usually only warm.
Can't complain about that.
dangerous ·
I have been using Ace Products (ACE 40 in my engines and synthetic in my trans now)
for the last couple of years and am very hapy with the results.
I chose the thicker grade due to the bearing clearances that I had built into the engine,
but may actually try the 30 grade at some time in the future.
It is always hard to change to a different brand than what you are used to,
but knowing that it is formulated for VW use by a VW enthusiast who is also an oil Chemist,
I thought I would support a product that was part of the VW scene.
I also agree that a lower viscosity should cool better than a thick one.
It will also use less power,
particularly if the engine never gets up to operating temp..... as for example in a Baja at this time of year.
