Shed tidy up time. Various parts, performance, porsche, turbo etc and other vintage style trim...
https://forums.aussieveedubbers.com/threads/76990/shed-tidy-up-time-various-parts-performance-porsche-turbo-etc-and-other-vint
2443TT ·
Hi Everyone,
Time to do a major cleanup of the garage. Here's the list of whats up for grabs. As for pricing, i'll accept any reasonable offer unless otherwise stated.
REVISED POST --- Everything in bold is now SOLD
1 x pair of CB performance ball joint dropped spindles, new and never used. $300 Sold to mountain bug
1 x pair of genuine 911 headlight lenses to suit a '66 headlight housing.
1 x custom flanged base intake pipe setup to suit a twin down draft IDF style intake forced induction setup. Its all polished 316 stainless, tig welded. The BOV can be included if desired, its a turbosmart 38mm V-Port (suitably named). I used this setup with the 2332 turbo engine that ran a 911 cooling shroud and a PWR intercooler. Bolt together intakes are the ONLY way to go to guarantee no boost leaks. The CB end castings leak badly under boost which is why I made these up. Bolt directly to the throttle bodies with a little silicon sealant, perfect seal. See the pic of the engine bay for how it looked installed.
1 x Custom turbo header, hideaway style with cylinders 1+2 exhaust gas going forward instead of around the back of the engine. All tig welded stainless. Has a 38mm wastegate on it too. This cost me a fortune to make. Pipe size is 1.5", T25 flange. Perfect for a 1916-2180cc. Most of the header wrap has come off since these pics.
$600 or best offer..
1 x alloy pipe to suit a T25/GT25 CB performance hide-away system, and match up to the above intake plumbing with an intercooler.
1 x set of 8 JayCee adjustable pushrod tubes. They need a polish and new o-rings but are otherwise in good condition, also from the 2332 turbo engine.
1 x SCAT straight cut cam gear set, limited use. -
1 x pair of alloy front gravel guards to suit a 1200/1300/1500, new in box.
1 x pair of alloy rear gravel guards to suit a 1200/1300/1500, lost the box... they need a polish.
1 x chrome lid spring, new
1 x pair of horn grills, new
1 x wolfsberg crest, new
1 x '65 and earlier number plate light seal
1 x empi pedal cover set
1 x pair of interior pilar scuff plates (they have white plastic stuck to them, but are alloy and can be polished)
1 x pair of door scuff plates (in the same picture as above)
2 x Porsche 993 17x7" ET55 rims
2 x Porsche 993 17x7.5" ET65 rims
(I'd like $1500 for the set of 4 but will seperate if required)
1 x pair of deck-lid stand-off's
1 x pair of porsche 944 turbo 4 piston brembo's, Need refurbishment but otherwise ok. $250 SOLD
All this stuff below is still available.
1 x set of 4 balanced Mahle 87mm slip in pistons and cylinders. (1641cc kit) They have grants top rings and total seal 2nd rings. and About 20,000Km on them. Teflon buttons. Sold to Drinky
1 x Empi 3.5QT Wide sump with extra fitting bungs welded all over it. Used this on my 2332 turbo engine and the fittings were used for returns from oil coolers and turbo's etc. Has a billet sump plate with magnetic sump plug in it too. All the bolts were drilled and upgraded to 8mm allen head screws. - Sold to fish26
1 x Revmaster Avaition Billet 38mm Oil pump with relief cover. This is the biggest and baddest oil pump you can getfor a performance engine build while keeping a wet sump setup. Sold to fish26
1 x pair of '66 and earlier headlight to chrome trim seals Sold to the karmanghia man!
1 x '66 interior light, new - sold to type3disease
2 x engine lid seals - sold to type3disease
1 x par of '66 and earlier tail light base seals - SOLD Anthiron
1 x pair of brand new '66 and earlier tail light lenses - SOLD Anthiron
1 x set of 8 ARP 8740 5/16th x 1.5" conrod bolts - SOLD Fish
Only 2 items left now! Might have to open up a few more boxes considering how well this has gone!
1 x standard pressure plate in good condition
1 x pair of 1988 Porsche 944 Turbo hubs.
$50
If you want more picture just ask and PM me an email address.
All parts are located in Cairns, but I'll post anywhere in AUS/NZ
I can be contacted on 0434 148 478 or 07 4033 7214
Ian
2443TT ·
More pics
2443TT ·
More pics...
2443TT ·
Intake setup...
2443TT ·
What it looked like installed..
2443TT ·
Turbo Header...
2443TT ·
more pics...
2443TT ·
More pics...
2443TT ·
even more pics...
2443TT ·
More pics...
LUFTMEISTER ·
p.m sent on parts as phone not responding. cheers
2443TT ·
Sorry... added a land line as well... Low battery i guess. PH: 07 4033 7214
2443TT ·
Jaycee Pushrod tubes, Scat straight cuts, and 911 Lenses - Sold
type3disease ·
hey Ian PM sent
ta Ben
hellbugged ·
PM re brakes and calipers Ian.....thanx
reub ·
Message sent dude... Will call over the weekend. Cheers.
Anthiron ·
hi ian.
how much do u want for the pre 66 lenses and seals?
Stanley ·
PM sent re 87mm B&Ps
2443TT ·
993 Rims sold pending payment.
Anthiron , how does $20 shipped for the lenses and seals sound? Pm me an address and let me know if your interested.
Ian
byronmcmanus59 ·
Pm sent
fish26 ·
PM on its way.
2443TT ·
Hi Guys,
Thanks for the huge response. Ive updated the first post with the items sold.
Another turbo pic too...
Ian
Anthiron ·
you have U2U ian
2443TT ·
Turbo header and intake piping all sold.
FROSTY ·
Hi Ian, Is that a complete Hex Cross Bar Linkage in the first photo? or just the end/center? How much?
Jason
2443TT ·
Yeah its the hex bar setup, but without the hexbar. Just check that CB sell them for 50USD as a kit with the ball linkage parts etc. If you still want it how does $30 delivered sound?
Turbo54 ·
Ian, how much for the revmaster oil pump. Would this be good for my turbo 2165?
Heath
2443TT ·
Turbo54 wrote:Ian, how much for the revmaster oil pump. Would this be good for my turbo 2165?
Heath
Yes indeed. Because of the size of this sucker you'll have good idle oil pressure even when your oil temps are getting well up there. Even with a 10w40 oil synthetic oil. Very useful if your running oil squirters for piston cooling. There is a pressure relief valve in the cover to stop over pressure happening too. (see the web link)
You should also get a pressure boost spring kit and the oil pressure adjuster to run at the flywheel end of the engine so you can setup the oil pressure to what you want. IE, 75-80psi at 7000 rpm.
http://www.revmasteraviation.com/products/vw_oil_pump/index.htm
Ian
Turbo54 ·
How much?
T54
2443TT ·
I paid $160USD. I'd be happy with $140 aussie dollars.
Turbo54 ·
Cool Done.
PM me your details.
Do I get the pressure boost spring and adjuster through revmaster or somewhere else?
Heath
T54
Turbo54 ·
Hey Ian,
1 more quick question. You had this in your Alloy case and i have a mag case. Do you foresee any issues?
Heath
2443TT ·
No I cant think of any reasons there would be a problem. Metalugicly speaking there shouldnt be any problems as both materials have nearly identical expansion rates. Factory mag cases used an alloy pump too.
Turbo54 ·
I just read your post on shoptalkforums about this pump. Did it clear your cam bolts etc with no modification.
I'll take it.
Heath
2443TT ·
Yeah it was fine. The bolts the cam was using was the standard ones that came with the scat gear set. I cant even remember doing a post on STF about the pump! Thats a sign that my project has been in progress for WAY too long...
Turbo54 ·
Ian - the rod bolts, are they used or new and would they be a good replacement for the ones that came with my Scat H beams? Going to be running 20psi. How much?
Heath
Stanley ·
Ian how much for the 87mm B&Ps?
Tried to ring mobile but it said it was disconnected.
cheers Andrew
FROSTY ·
Hi Ian,
I will take the Hex linkage parts, just sent you an email.
Thanks Jason
2443TT ·
Hi Guys,
Lenses and '66 tail light seals sold to Anthiron. Will be freighted Tuesday.
Pending if he has paid or not I think fish26 has the empi sump, revmaster pump and rod bolts. fish26's last PM is un-clear about the payment. Sorry Heath, your next in line for the pump if he changes his mind. I think you both might have paid for the pump/parts around the same time and fish26 didnt see your post sayign you'd take it...🤪 Anyway it will work out and i'll refund whoever had their payment come in 2nd if thats the case.
Drinky has 1st dibbs on the 87mm p&b kit. fish26 is 2nd.
Mountain bug has the dropped spindles.
I think thats about all. Will be updating the first post shortly...
Ian.
2443TT ·
Stanley wrote:Ian how much for the 87mm B&Ps?
cheers Andrew
Thats odd... i had it with me all day and took a few calls.
My landline has flat batteries in the cordless phone now. Talked to Luke too long last night...
Im pretty sure either Drinky or Fish26 have dibs on the barrels first, but otherwise $100 + delivery and youve got 3rd dibbs...
Ian
Stanley ·
no probs Ian.....thanks
Turbo54 ·
Ian, I said I will take the pump but still waiting for payment details from you.
I hope fish bails out. Let me know as this would be great for my turbo motor.
My contact is 0434 943 058
Heath
2443TT ·
Sorry Heath, seems Fish26 got in 6 hrs before you and has already paid. There is an autocraft 1 1/2 stage pump on ebay that might also suit your application. You can have a seperate sump under the turbo to collect turbo and rocker cover oil, and then run the 1/2 stage scavenge from that to return to the side of the vw engine block. The pumps first stage works as a wet sump pump otherwise.
http://cgi.ebay.com.au/AUTOCRAFT-VW-1-5-STAGE-DRY-SUMP-PUMP-NEW_W0QQitemZ300320050215QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item45ec784c27&_trksid=p3286.c0.m14&_trkparms=65%3A1%7C66%3A2%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Only type3disease, dub61 and the guy that bought the wheels have had their payments clear so far. Those that have already paid for stuff, I have boxed up the parts and will ship them off tomorow mid-day ish after checking my account again.
Dave, (drinky) has the p&b kit, waiting on payment. Mark, Picture is emailed for the 944 spindles and hubs.
Main list is being updated in a few minutes .... a few more parts sold.
2443TT ·
pic of the hubs....
FROSTY ·
Hi Ian, Received the Hex-end, Thanks again Jason
2443TT ·
No probs thanks for the update.
Just about everyone's stuff was all sent on the same day. So if you havent received it today expect it tomorrow.
That is except for Luke's turbo header, which I finally was able to find a big enough box for to fit it in on the weekend. It left this afternoon as well.
Ian
