In want to put my 2L box on a worked 1600 obviusly for the ratios. What is needed to put the gearbox on the engine?
Joels72Lowlight ·
And what kind of price?
I woould rather make my own adaptor.
I remember someone mentioning you have to change the input shaft.
13bwagon ·
i don't know but try swapping the bell housing and flywheel
i maybe off course a but im pretty sure u would only need to put the shorter input shaft in the gearbox to suit the 1600 needle bearing
cos they all share the same bolt pattern, ring gear and throw out bearing
dangerous ·
You can keep everything except the input shaft as Joel says.
Some keep the input shaft and just shorten the end.
This works but is hard to make it look nice, without removing it from thr trans and doing it in a lathe.
If you want a "worked 1600" from some other manufacturer, like toyota or nissan,
then yes an adapter plate might be required.
Joels72Lowlight ·
No Im putting it on my 1600 that I wil be doing up my self.
Joels72Lowlight ·
Its a 1600 type 1.
How much shorter will I need to do it?
there ya go straight from the gearbox guru
type1 are about 10mm shorter than type4 from memory
71EJVan ·
I have a 2 litre box in my van with a 1600 (002) bellhousing and input shaft. 200mm clutch. No problems.
themadpostie ·
Apologies for my misleading post.... I removed it.... the kit stuff from John Sherman I was refering to had to do with my racecar.... which needed the box to be flipped upside down so we could transverse mount the gearbox to the engine. The ring gear is offset.... long story.... anyways.... carry on!!! LOL
