I bought a second hand re-conditioned one and need to by a ECU for it !
Any help would be great !!!
Thanks James
MickH ·
check the date under the oil filler cap....
Manxdune ·
They put a Brand New filler tube and cap on ! Damn it...
I have the engine block serial number but I cant find a cross reference to the year it was made !
any other ideas guys ?
Thanks James
mine had a new cap and filler too, didnt think it was an 06 engine 😂
u can find the date on a few other things
mines got it inside the timing belt covers on the 3 pieces and also on the throttlebody
Manxdune ·
Thanks Joel,
But mine has new timing belt covers as well as it was a fresh engine rebuild !!!
Doesn't the engine block number mean anything ???????
I NEED the engine year so I can purchase a FULL WIRING HARNESS and CPU !!!
Is it something to do with the shape of the engine wiring harness plugs ???
Why do alot of people have the conversion but no one knows where a cross reference chart is between engine serial number to manufacture year ???
HELP ME IM GOING CRAZY.....
Thankyou all James-
the timing belt covers get munched in front enders so theyre often not original,
just trying to think were else ive seen mine dated
i know my throttle body has the date stamp on the top somewhere
think its somewhere near the TPS
little circle with the year in the center and months around the outside
from memory its the 89-94 engines that have the 3 grey main connector plugs between 2 & 4 injectors and crank/cam/knock sensors bolted to the bellhousing like mine
