thinking about buying a brazillian 1600 long block anyone had any experiance with them? good, bad ?
Bizarre 路
yeah - they run very SMOOTH 馃榿
Seriously - what you want it for??
Stocker??
A few things arent as good as OG - cast crank for example.
But they are all new
mackaymanx 路
If you mean the "Mexican" motors, yes I have one in my '65 Notch. Have not had any trouble with it.
Originally ran it in my Manx, went from Mackay to Mt Isa and back with it. Only add on was a full flow filter/pump.
I later converted it to a type 3 setup for the notch and a remote mounted filter.
They don't come with a distributor drive shaft.
sgetty 路
yeah just a stocko for my 64 mated to 1500 box
1916baja 路
I had one in my manx. Had alot of trouble with it and ended up building a new motor after a year. For some reason it burnt out 2 valves. Was regularly serviced by Good Vw mechanic and no-one knows why this happened??? Although it did get us to valla and back with burnt out valves... It always got us home no matter how bad it was running!
