ok its time to clean out my stockpile of VW bits and peices.
59ish baja bug, no guards, seized engine, body is rusty as hell. floor pan halfs are rusty and pan is in questionable condition, not rolling as steering knuckles seized no wheels
Things that are good on it: has swinger gearbox (unsure of condition), glass, ice pick door handles, front end (steering knuckles are seized currently), seat rails (attached to some random seats that arent much good)
TAKE IT AWAY FOR FREE
71superbug, body is rooted, c pillars very bad, every guard is slightly bent, has been in a slight front ender at some point and bonnet and front valance dont quite match up and lock, no engine, no starter. Rolling, steers and stops.
things that are good on it: twin side place IRS + axles etc (complete rear end, this was working great before a sold the engine a couple of years ago, cant see why it wouldnt now), Steering box (hard to find), Disc front end (could use for a conversion), 4 stud stock wheels, fuel tank, Glass.
Cheap IRS parts for conversion, Make me an offer and take it away! SOLD
63ish (cant read the vin) baja, this car is completly dismantled but most parts are there. Body has rust around corners of front bulk head and lower sides of footwells but is fixable, Pan has rusty halves but is very usuable with some replacements, no baja kit, no engine, no starter, one axle needs to be re attached to gearbox + tube attached to springplate etc. will need a rear drum for that side to roll but i think i have one somewhere, can put it on some mis matched wheels to get it rolling once the axle is back in etc. has doors, glass, bonnet has been cut back to use with baja kit, fuel tank, bolts and bits etc to go with it and assemble into car once rust is fixed.
make me an offer and take it away!
other parts:
bug eye baja kit, very good thick guards (hard to find some as solid as this!) missing rear cover.
wide eye front guards and nosecone (these match up to the 63 baja bonnet.
stock early 60's beetle front guards (pair) with horn grilles in good condition.
2X generators in unknown condition
late 50's fuel tank
baja front bar (just needs mounting brackets)
2x wide roh rims with stock VW centers unknown offset (SOLD pending)
early speedo in miles (coloured plastic for warning lights is loose, seems ok otherwise)
weber 40dcn14 carby and manifold (dont know where this is but ill try to find it) (SOLD pending payment and finding it)
4into1 baja extractor exhaust, a bit rusty, might be ok with a new muffler.
plus some other gear ive forgotten.
MORE PARTS ADDED:
009 dissy
71super dissy with vacumm
Clutch disc almost brand new just has surface rust (can measure)
coil clamps (one with a coil)
assorted headlights
oil temp guage
oil pressure guage and sender (oil line kind, just needs oil line)
VDO clock
stock fuel guage
wing mirror
set of 14 inch peco style rims with good rubber, 195(i think) khumos on the front wiht 85% tread and 235 bridgestone eagers on the rear with just passable tread. (SOLD )
couple of other random wide 5 rims
also have stock 6v flywheel and clutch, flywheel teeth in ok condition, (i ran it for years and the starter never missed) clutch almost brand new. (went to 12v stuff so i dont need it)
make me an offer on the 63 with a package of baja kit and wide wheels perhaps?
all parts are located at Carters Ridge behind cooroy
0439737762 (i will check this every day, easier to post or U2U)
Nicko
seriously, stupid offers please. i need this stuff gone.
Anthiron ·
