Carb Problem?
https://forums.aussieveedubbers.com/threads/77345/carb-problem
homer ·
We have a 1600tp with a 34 pict3 and it seems to be ok around town but if is on a run at 80k it loses power and dies.If i start it back up it will not rev(just splutters and stops).It i leave it for a while it will go ok but only for a few hundred metres and does it again.i will start by changing the fuel filter.Thanks in advance for any help.
donn ·
I had that problem recently, tried all sorts of things then the 3rd NRMA bloke to look at it removed the fuel filter, no more probs, have since replaced with a new filter and all's sweet.
homer ·
checked the filter and found a hole in the hose.changed the filter and hose but it has not fixed the problem. i can at least keep the car running now.
