balljoint beam with adjusters/spindles
https://forums.aussieveedubbers.com/threads/77380/balljoint-beam-with-adjustersspindles
grogy ·
hi, i got a type1 balljoint beam [not narrowed] with adjusters and standard spindles very good condition. $200 call greg 0414267430. sydney
grogy ·
bump
trickysimon ·
Got any pics?
baywindowbandit ·
Does it have the brakes on it still?
grogy ·
hi no brakes, no arms , just beam with leaves n spindles .sorry i can post pics it says they are too big. not sure why as i have posted on other adverts using same camera ,same everything.........ps if u send me u email i email u pics
Impulsive ·
Hi Grogy.
What area of Syd are you in? I'd be interested in a couple of pics if you don't mind, especially around the brakes area. Do you know if brakes off an earlier swing axle chassis will fit your spindles? I assumed they would, but I'm a novice at this stage, so your advice is appreciated.
If you could send a couple of pics to adandjules@gmail.com, I'd appreciate it.
Regards,
Adam
grogy ·
hi, is your front beam a ball joint or link/pin beam, i know the mounts to the floorpan are diff, so one cant be mounted to the other floorpan
grogy ·
still available
grogy ·
bump
grogy ·
bump
