Hi,
Just put my clutch back together, had the flywheel machined and bought a new clutch plate.
I noticed, though, that splines on the old plate fit around the input shaft fairly snugly, whereas the new plate's splines have a little 'play' on the input shaft. It still meshes with the splines fine, just a little looser (slight backlash, i guess - the differnce would be less that 1mm). Is this ok, or will it pose a problem?
The plate is the same shape and size otherwise, although the facings are different material.
Your help appreciated.
joshuah ·
