As some of you are aware, I'm rebuilding my Formula Vee at the moment.
I wanted to ask advice on an issue the car had before I stripped it down.
I could never get second gear from first.
No trouble getting second from third.
No grinding..... just can't find the gear.
Is there a staggering of the pattern from first to second?
If so that might be the problem, as the shift linkages were a little loose.
Otherwise.... what would cause it not to be able to engauge second gear?
Thanks in advance.
Postie.
themadpostie ·
