about a week ago i decided to change my avatar, but it kept stuffing up, tried on a different computer same thing, made sure that the pic dimensions and byte size is within the recommended size. still wont let me change it, all i can do is use one of the standard pre-loaded images.... anyone else having this issue? like i said, it was fine before and i and iv already had custom avatars so ts only a recent problem.
cheers adam
TopGun ·
polak,
I'm having the same problem. I sent a message to the moderators but haven't had a reply yet.Have you been able to find a solution yet?
Cheers.
it seems to be abit fussy on them sometimes
ive found saving them in gif format helps keep size under 15k for some reason
polak ·
Hey Topgun, no news at this stage, ill let u know if anything works out
u should be able tochange them your self but it also may not allow you as Andrew did some chenges a while ago
