For sale is a pair of dropped spindles to suit a ball joint kombi beam. They suit 73 on discs and calipers. Normally these dropped spindles widen the track by 13mm per side, however these ones have a little extra machining and bracing to be able to provide a zero increase in track.
The price is $700 exchange if possible. I can also provide rebuilt calipers with new pads and machined discs for an exta $200.
Please contact Geoff on 0416067932.
How much lower?
urban_myth ·
forgot to say. they are 2inches or 50mm in drop
vwsteve ·
can you make raised spindals mate?
urban_myth ·
i have not made raised before.how much did you want the spindles raised? they can be made but will widen the track.you would need to supply me with two sets of spindles to make them.unsure of the cost at this point as they may require an extra plate to be added for strength and some shear pins fitted.give me a call to chat further on 0416067932.thanks
urban_myth ·
price update, $700
Notch65s ·
can these be made for 72 mdls?
urban_myth ·
yes they can be made to suit 72 models.call me on 0416067932
LIFE IN THE LOW LANE ·
you are stating on an exchange basis - is that for 1 complete set of spindles in exchange for the dropped set? I am interested as are a few other I know of.
urban_myth ·
To make one set of dropspindles I need 2 sets. Sometimes I am able to find some so 1 set as exchange would be welcome. normally these have an offset of 13mm per side, at a cost of $700.to make these with zero offset requires an extra gusset to be fitted to the back off the spindle as the picture shows and further machining is necessary, hence a further cost is required off $100.using one set off spindles I can make a 50mm or 65mm drop spindle using commodore vt hubs which will then give you bigger vented discs and callipers and commodore studpattern. This gives the advantage off using offshelf slotted and drilled discs or larger 4 piston callipers and discs. .the brake hoses need to be shorter. A good chance to use braided hose. Cost is $900.this includes second callipers. I am in the process of using the rear bearing housings of the vx commodores and machining these to be a bolt on set up .this will give you an internal h/brake and vented discs all locally made.; the work needed is fairly substantial and will probably cost around $1500 for a complete setup. Ring me 0416067932.its easier to talk than type. Thanks
