Aussieveedubbers · Bugs
Dodgy Windscreen Wiper!
https://forums.aussieveedubbers.com/threads/77754/dodgy-windscreen-wiper
Linz ·
I just bought my first Bug, '63 model, but the driver's side windscreen wiper is a bit dodgy! Works every now and again and then just dies. Passenger side is fine - any suggestions??
Thanks!
sander288 ·
look for dodgy groundings under the front, check the switch, and if all fails get it to a VW shop to fix it, i've just had my wipers fixed by vintage vee dub, and it is worth it!!
grumble ·
If the left hand side works OK and the rght hand is i.s shonky look for a slipping wiper arm or weak spring clip giving low pressure on the arm on the right hand shaft as both sides are driven from one motor
Mountains Greg ·
Sounds like the wiper arm may just need tightening. I think it is a 12mm nut at the base where it attaches to the pivot.
