Its to a 1969 irs pan, the bearings in the arm. i been trying to pry and hammer a screwdriver between teh mating surfaces of the seal and bearing... no luck to get the seal out.
even got a decent socket and extension with a big hammer to try knockin it out from the outside. is there a big circlip or sumfin holding it?
I don't have a bearing puller, but if anyone can suggest some bush mechanic methods they would bemuchly apreciated. i tried to pull it out with a spring compressor and a differnt nut setup, it simply just kicked it with the inaminate bearing not budging.
thanks,
Chris.
bajachris88 ·
