WTD Aircleaner Assy for Holley Bugspray
https://forums.aussieveedubbers.com/threads/77814/wtd-aircleaner-assy-for-holley-bugspray
dbbaja ·
Am Looking for a Air Cleaner Assy for a 3110 Holley Bugspray Carby 2 5/8 neck. Condition Does not have to be showcar but more complete the better.
My location is in Toowoomba Queensland.
Either pm me or email at
dburton@sxauto.com.au.
Many Thanks
Darren
Anthiron ·
i just used a pod filter from super cheap and got a piece of that silicone intercooler pipe also from super cheap, interior diameter fitted the bug spray and the exterior fitted the pod, 2 hose clamps and its all sweet.
I think i have one, will have a look tonight for you.
dbbaja ·
I have thought of the Pod filter way but it doe's not give me the look I am after.If no luck will have to adapt[cut and weld] another aircleaner to fit.
Darren
guru ·
I used a mushroom filter with a chromed truck front wheel centre cap to cover the mushroom. Spaced the cap up with a nut for air intake clearance. Fitted perfectly, looked tidy and did the job.
Old Hutcho ·
Mate, try a RamFlo by Lynx engineering. You know youve seen em forever, specially on those old racers. I use a set on my twin setup on the 1916 and one on my stock PICT 34. They flow well, you can oil them if you like and boy they sure do look the part. About $65 will get you one complete, in chrome.
Go here http://www.lynxcorp.com.au/main.php?idx=ourproducts
Old Hutcho
guru ·
Yep, thats the same style I used except mine was round.
dbbaja ·
Thanks for all the good advice.
The Lynx Air Cleaner will do the trick.
My local speed shops all said that no one would do one, but now armed with a part number I will be able to get one ordered in.
Thanks Again
Darren
