l bug baja
https://forums.aussieveedubbers.com/threads/77836/l-bug-baja
baybug ·
i have a 74 l bug (curved screen) convertable i bought as a project and am still thinking about ideas. someone mentioned the idea of baja bug. most of the ones i have seen are early bugs. has anyone done a 75 l bug baja? is it possible? what problems could i encounter - especially being a convertable?
Anthiron ·
the search button is your freind!
in short. dont do it, it will make a crappy baja
strut bug bajas have been done and some even work really well off road but takes alot more strengthening than the old tractor front end
shaihulud ·
I assume that you have a MacPherson Strut front end. If you do then you have a problem.
If you look under the car you will see that there is a big suspension support, with the sway bar attached protruding out at the front.
That cannot be removed, so it means that if you make the car into a Baja you will not have removed the bodywork at the front to give good entry into creeks and at the bottom of sand dunes. You will dig in at those places. They therefore don't make the most versatile Bajas.
If you do make a convertible into a Baja, you will find that you will get a lot of scuttle shake when in the rough, off road, as they are just not rigid enough. I used to have a home made convertible Baja, and I know wherof I speak.
Before I sold it to someone who will probably never take it off road, I was seriously considering welding the doors shut.
For the best Baja you really need a torsion bar, trailing arm front end and a sedan body.
baybug ·
thanks guys, looks like you have saved me from a bad idea!!! wife is happy though she wanted the "porsche" style wide gaurds and body kit
cheers and thanks again for the advice😎
baybug wrote:thanks guys, looks like you have saved me from a bad idea!!! wife is happy though she wanted the "porsche" style wide gaurds and body kit
some would say thats just as bad 😂
if its already had the roof cut off so the poor things death certificate is already in the mail, so may as well make something fun out of it
baybug ·
something fun is the plan
dekkerboy ·
You could just get the baja kit and do a half baja but i agree with everyone else and it will probably make a crap baja.
